89 E-150 5.0 master cylinder mounted valve
Changing out master cylinder and booster, but when bench bleeding the new master cylinder I found the proportioning valve appears to be leaking, very small air bubbles showing. Looked on line for these valves but can't find one that replaces it. Did a disc/drum job a few years ago and it appears my rear drums had very little use, replaced wheel cylinders and front calipers, but not master. I suspect the valve on the master has not worked for a long time.
Thinking about eliminating it and using an adapter. Anyone else have a similar experience with this?
mudrunner4ever
04-05-2013 06:35 PM
geaux tigers
12-07-2006 05:48 AM
Katmandu2
08-14-2003 05:07 AM
