2000 PCM interchangeable for '02 engine?
I bought a 2000 F250 Super Duty 7.3 Powerstroke, 4x4 with automatic transmission. Was told the engine was replaced with a 2002 crate motor. I am trying to determine if my PCM matches the motor. Engine number: T444 LF 250847 followed by 112 0303
Can't find any information online about the engine. The PCM is number: F5SB-14A624-AA struck out on this one too.
Received 3,090 Likes
on
I am looking at crate engines like these people sell
POWERSTROKE CRATE ENGINE
I see no sensors or wiring on them at all. So I am thinking when it's swapped in, all the top engine dress from the old engine goes on the new, and should be compatible with the old PCM.
Stewart
I see some replacement engines do have the sensors:
https://www.powertrainproducts.net/p...3z6006aarm.htm
The PCM ID engineering number: F5SB-14A624-AA struck out on this one too, probably because this is not a part number.
If you don't have the VIN from the vehicle that the swapped engine came from, the parts guy can look thru the applications or Calibration Code charts to find the part number.
Then you'll know if it's the same as yours....or not.
The only thing I can tell you is: F5SB is the ID engineering number prefix for a 1995 Thunderbird, but this doesn't necessarily means that it's incorrect.
One thing parts guys learned when Ford began installing computers in the early 1980's. If the engine was swapped, the original computer usually didn't match the swapped engine.
So whatever vehicle the engine came from, you also needed the computer from it. Use the original computer, the engine could run rough or it might not run at all!
If it is in fact a 2002 engine, then a 2000 PCM will run it no problem. There are no different sensors or data that the 2000 PCM would expect from a 2002.
Yes, the PCM is different. Primarily in the communications protocol and charging system but nothing in the way the engine is controlled. Repeat codes after replacing components that are "faulty" means that the parts weren't faulty.
Okay, the codes I keep getting are P0670 = Glow Plug Module Control and P1690 = Wastegate Control Valve Malfunction.
Put a new Glow Plug Control Module (California style, not solenoid) in. While doing so I checked the continuity of the glow plug circuit to each plug.
I then purchased a new Wastegate solenoid and hose kit. Before installing I applied 15psi to the actuator and it opened and then closed when I relieved the pressure.
Cleared the codes by disconnecting the battery and operating the horn circuit for 30 seconds.
Truck seems to run fine but the codes come back.
Oh, and I took out the PCM again and found some numbers carved into the plastic connector. 8677F which a online search came up with a DPC-452 PCM.
