1989 f150 4.9L 6yl, efi temperature guage - Ford Truck Enthusiasts Forums
Old 06-17-2017, 09:30 PM
MADCleveland MADCleveland is offline
MADCleveland is starting off with a positive reputation.
My temp guage in the dash didn't work very well and now not at all. I've changed the sensor (one wire, lower right side above starter) and the guage tests correctly when grounded --- needle moves to the far right of the dial. However, the the gauge is connected, the guage does not appear to be working.
The needles moves to the left a bit when the ignition is engaged and stays there until the engine is shut off. The guage needles them moves slowly to the right to its original position (on the C).
Any suggestions what the problem may be. Thank you.
Old 06-18-2017, 11:13 PM
ChRoNo16's Avatar
ChRoNo16 ChRoNo16 is offline
ChRoNo16 is starting off with a positive reputation.
I dont know the 4.9 very well, best advice I can give is to warranty out the sensor it may still be bad.
also check to make sure the thermostat is opening properly.
Old 06-19-2017, 12:38 AM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Try grounding the gauge wire with the engine running and verify the gauge goes full-hot.
Old 06-19-2017, 09:54 AM
DPDISXR4Ti DPDISXR4Ti is offline
DPDISXR4Ti is gaining momentum as a positive member of FTE.
Quote:
Reading above, it sounds like he's already done that.
Did you use Teflon tape on the switch? Maybe you're not getting a good ground with the threads to the block. I also agree that you could have a thermostat stuck open, but this time of year you'd usually eventually warm up, just more slowly.
Old 06-19-2017, 12:09 PM
I mean grounding the gauge wire with the engine running vs. just key on.
Old 07-06-2017, 08:23 PM
Yes, gauge goes full hot when grounding sender wire with the ignition on, engine off.
Continuity between thermistor in block to battery ground cable is good.
ECT manual shows a circuit from something called an engine warning unit to the temp gauge and down to the thermistor.
Gauge is replaced as is all components, thermistor, hoses, coolant temp sensor up front on thermostat housing, thermostat.
Problem must be on hot side of temp gauge but not sure what. Gauge seems to get power as it moves left when the ignition is turned on and returns to "C" when ignition turned off.
Old 07-07-2017, 01:08 AM
What does the gauge do if you ground the wire engine on?
Old 07-07-2017, 05:45 AM
I will test it and get back with you.
Speedometer not working- 1988 f150 Brad9907 Electrical Systems/Wiring 8 08-27-2017 08:44 AM
1989 F250 Temp non-functioning guage philv 1987 - 1996 F150 & Larger F-Series Trucks 5 01-01-2017 11:31 AM
Fuel Guage not working TheGreaseMonkey88 1987 - 1996 F150 & Larger F-Series Trucks 0 08-13-2016 07:50 PM
Gas guage and temp guage not working. Voltage regulator? Frmnsal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 06-23-2016 07:40 PM
Oil pressure guage reading wrong Goinnuts 1961 - 1966 F-100 & Larger F-Series Trucks 9 12-02-2015 04:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
