5.4 Triton fluctuating oil pressure? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-17-2017, 05:04 PM
Joshua Hurst Joshua Hurst is offline
Joshua Hurst is starting off with a positive reputation.
Question 5.4 Triton fluctuating oil pressure?
So I have a 2002 Expedition EB with the 5.4 with a little over 355,000 miles (ye s I know that's allot) We purchased it at 230,000 and was fleet owned and maintained before that. It had given us 20,000 miles of trouble free use, from long vacation trips to 200 mile trips pulling 5,000 lbs. But let's get to the problem... Recently went down the interstate, all of a sudden check engine light comes on, oil pressure drops, engine starts shaking/knocking. Get it to a shop, they look at it, change oil, and wasn't for sure but figured engine was maybe a gonner. Tow it home, and when you crank it, starts out fine and oil pressure on dash is good, then after a few seconds drops down, then goes back up and eventually stays up and truck will run fine besides a light knocking sound. Not for sure what is wrong, figured maybe oil pump, but figured motor would have blown already. I seen something about a oil sending unit, could that be the culprit? I have no idea, and with that many miles it could probably be numerous things that failed. Thanks in advance
Old 06-18-2017, 08:01 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
A failing oil pressure sensor can make the gauge fluctuate or drop to zero, but it wont make the engine run poorly.
You need to get a mechanical oil pressure gauge installed temporarily so you can monitor the actual oil pressure at cold and hot. From there you might get a clue on which direction to go.
Sometimes a bad oil pump can mimic the symptoms of a worn out engine, so without tearing into the bearings it could be tough to figure out what's wrong.
Ar that mileage , it could just be worn our. But with that said, those 2v 5.4's have gone over 1.2 million miles before they are shot, so it depends on maintenance and how it got used previously.
Old 06-19-2017, 03:16 AM
Skauber Skauber is offline
Skauber is gaining momentum as a positive member of FTE.
And don't rely on the oil pressure gauge in the dash, it's not a real oil pressure gauge. It's just a glorified "low oil pressure" lamp. It only has two readings - "normal" and "low", nothing else. The "sensor" in the block is actually just an oil pressure switch which only has two states, on or off. If your gauge is fluctuating between "normal" and "low", it means either that the switch or wiring to the switch is bad, or that the oil pressure is so low that it barely makes the pressure switch turn on. If it's the latter, then it could be either low on oil or something clogged, such as oil pickup tube, filter or oil channels. Other causes for low oil pressure is a failing oil pump, or worn out journals or main bearings, which basically means the engine is worn out.
Old 06-19-2017, 08:56 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Sounds like a spun main or rod bearing.
Expedition 5.4 Help Joshua Hurst Modular V8 (4.6L, 5.4L) 2 01-21-2017 08:56 PM
Low Oil Pressure Derrrrick 1987 - 1996 F150 & Larger F-Series Trucks 9 10-22-2015 10:46 PM
no oil pressure xcrmk Modular V8 (4.6L, 5.4L) 5 03-25-2015 07:23 PM
Oil pressure issues crotalus258 Aerostar 8 07-08-2011 04:38 AM
what normal oil pressure for v8 5.4L Milwaukee1979F150 Modular V8 (4.6L, 5.4L) 4 04-03-2009 08:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
