Broken Parking Brake cable inside drum - F250 1990 HD
Hey everyone!
So.. started to feel some dragging in the brakes after my parking brake spring fell off about a month ago. I put adjuster spring back on but it's not been the same since.
Today I pulled off the drums and started inspecting the hardware.
I discovered the cable inside the passenger side drum was cut which suggests that my parking brake is the culprit.. pictured below is the broken cable..
Could someone give me the bad news? Is this a short cable that attaches to the spring where the longer external cable attaches to? Is is perhaps a job where I should replace all of the brake cables?
Thank you inadvance!
Busted!
Busted!
The piece that is just above your finger that is holding the broken cable, I believe that is where that(broken) cable pivots around. That piece looks too rusty and deteriorated to hold that cable on place.
The other end of the broken cable should hook near the bottom of the assembly and holds the other end of a brake spring via another piece.
How much you will need to replace right now depends on the general condition of other things.
Received 3,102 Likes
on
That is a self-adjuster cable and not a "parking brake" cable. Your "parking brake" is not a parking brake it is an emergency brake. Everybody calls it a parking brake sometimes.
Buy hardware kits and adjuster kits and replace everything except the shoes for very little money. They are so cheap I keep the kits at home for spare parts. Do both sides.
Your "parking brake" faded because the adjuster wasn't working. Your brakes were probably pulling too the side a little to if you tested them. Testing them is a good habit. Every so often hit the brake hard and give the steering wheel a little leeway to see if the truck veers to the side.
I have gotten them stupid cheap from rockauto on clearance.
The following users liked this post:
Back to the OP - why is everything wet? Did you just lube it with something? If not, you may have a hydraulic leak back there. As said, would be best just to get a complete rear drum hardware kit and replace it all. Some kits come with that cable and some don't. You'll need to see a pic of the kit you're ordering to be sure. Do ONE side at a time, so you have the other for visual reference.
And as said above, look into a possible wheel cylinder leak.
Broken SELF ADJUSTER cable...
I discovered the cable inside the passenger side drum was cut which suggests that my parking brake is the culprit.. pictured below is the broken self adjuster cable.
This cable, in fact every self adjuster cable...installed beginning in 1961 is notorious for snapping.
Hardscrabble: FoMoCo = parking brake cable, not emergency brake cable.
Ford car & truck parts catalogs have Parking Brake Application Charts, not emergency brake application charts.
I looked at a Lincoln from the late 20s in a museum. It had a placard saying it was one of the first cars that could maintain 70mph over a distance, like all day. In the late 20s many roads were still dirt. That car had no front brakes as delivered new. Rear brakes only and probably cable operated or rod operated. Can you imagine stopping something like that with those skinny tires from 70mph? On a dirt road? Parking brake my A$$.
I got those words from rockauto. If you don't like my words, tell them if you don't like it.
on
Did those brakes have bands that clamped from the outside or expanding shoes on the inside of the drum? I have seen the bands on some cars and they were exposed to the weather, water, mud and road grime etc. Driving was a skill and a privilege then. Now people act like it is an entitlement and a bloodsport.
on
if i remember correctly the model "T" had band brake, it was on the output shaft of the transmission, and not very effective at higher speeds.
below 25-30 mph they were not that bad if you remembered what you had, up around 50-55 mph, they would slow you down.......eventually.
