Broken Parking Brake cable inside drum - F250 1990 HD - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-29-2017, 12:27 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown Bad Bad Leroy Brown is offline
Bad Bad Leroy Brown is starting off with a positive reputation.
Quote:
Originally Posted by tsevrens View Post
Hey everyone!
So.. started to feel some dragging in the brakes after my parking brake spring fell off about a month ago. I put adjuster spring back on but it's not been the same since.
Today I pulled off the drums and started inspecting the hardware.
I discovered the cable inside the passenger side drum was cut which suggests that my parking brake is the culprit.. pictured below is the broken cable..
Could someone give me the bad news? Is this a short cable that attaches to the spring where the longer external cable attaches to? Is is perhaps a job where I should replace all of the brake cables?
Thank you inadvance!
Busted!
Easy to replace, you need something like a 10mm right above the brake piston on the back side of the backingplate. Take that nut off and Tap the long screw out from that side or gently pry the stack of parts held on from the outside.
Replace that cable, ensuring to hook it onto the brake adjuster claw correctly, and grease the friction points in that stack of parts with a moly assembly lube like M-77 paste to keep the parking/Ebrake moving freely.
I had to tap the screw back through those parts using a deep socet because its somewhat a friction fit.
Loctite the nut on the back of the backing plate and you are ready to put the drum back on, but it sounds like you need to replace or rebuild the piston while you are in there. (hint: if you get the motorcraft pistons they are really nice and made in Italy instead of China!)
Good luck, let me know if you have any questions or need refrence photos!
65 brakes BOB'S 65 1961 - 1966 F-100 & Larger F-Series Trucks 2 03-07-2017 07:49 PM
Replacing the adjusting cable parcher440 1987 - 1996 F150 & Larger F-Series Trucks 4 10-06-2016 12:35 AM
Is there any way to adjust the parking brake pedal? Shadow351 1997 - 2003 F150 7 03-15-2016 05:55 PM
F350 Drum brakes Pi$$ing me off uniwagon 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-04-2015 02:16 PM
65 F350 Parking Brake Parts 62FE4x4 1961 - 1966 F-100 & Larger F-Series Trucks 6 09-30-2015 05:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
