Pictures: In Bumper LED Light Bar (zRoadz) - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-17-2017, 11:05 AM
bushpilot bushpilot is online now
bushpilot is gaining momentum as a positive member of FTE.
Yesterday I installed the ZroadZ 12 inch light bar (ordered Tuesday, arrived Friday via Fedex / free shipping)...
Everything you need (and more) is supplied in the kit (I wired it to up-fitter #2).
I have the proximity cruise and was unsure of the fit, but took a chance (w/ the agreement that I could return it if it didn't fit or I didn't like it). I trimmed the side of the proximity cover slightly (once everything is back in place you can't even see where I trimmed it), I felt trimming the cover was necessary to prevent the zroadz light bar / heat sink from hitting the proximity cover.
Installation wise the ZroadZ wiring harness is included (switch and relay) and are high quality) but you don't need them...just run the wire from the lights, to a ground and connect the (red) hot to an up-fitter....
you DONT need to use the ZroadZ fuse, relay or switch (since the up-fitters have all that incorporated into the wiring/box).
I kept the zroadz inline fuse and grounded to an existing factory ground (close to the up-fitter stub wires/fuse box) on the drivers side fender.
you'll do best to remove the grill, but its not completely necessary....and you'll want to remove the proximity cruise/radar cover (makes mounting the light bar easier)...and you'll have to trim the radar cover a little.
initially the BEAM pattern of the light bar seems kinda narrow (but I went for a short cruise on a dark / narrow road w/ all the other lights off) and realized there was more side light projected than I thought.
I think it looks MUCH nicer than the black hole (w/out a front tag)....over all I'm pleased.
Old 06-17-2017, 11:42 AM
Mach169 Mach169 is offline
Mach169 is starting off with a positive reputation.
That looks nice!
Old 06-17-2017, 09:43 PM
XXLTexan's Avatar
XXLTexan XXLTexan is offline
XXLTexan is gaining momentum as a positive member of FTE.
Amazing... going on my short list of mods$$$$$$$$
Old 06-17-2017, 10:10 PM
MagicMtnDan's Avatar
MagicMtnDan MagicMtnDan is offline
MagicMtnDan is starting off with a positive reputation.
Looks great! Thanks for posting. Is there only room for a 12" light bar there?
Back in the day (2009) when I got my Raptor I talked to Rigid about making a light kit to fit that hole in the Raptor/F-150 and they did. For their 20" light bar.
I was possibly the first to do that and many, many have done it since.
Old 06-17-2017, 10:41 PM
Quote:
with the proximity cruise control (box) on the drivers side, the largest light bar that will fit (centered in the bumper) is 12 inches.
Old 06-18-2017, 12:34 AM
BADAS03SVT BADAS03SVT is offline
BADAS03SVT is gaining momentum as a positive member of FTE.
12" for $200?? better put out some light!
Old 06-18-2017, 09:01 AM
Quote:
so its probably not for you then.
considering that a 10" Rigid Industries will run $400 (retail) / 300+ (street),
I don't think the pricing is out of line....theyre specs (5780 lumens) and warranty are in in line w/ the zROADz (5800 lumens / lifetime warranty)
you can buy the 12' light bar from zROADz for $139
feel free to make your own bracket, design your packaging, put up a website, market it and include shipping (good luck w/ dat).
Old 06-18-2017, 10:17 AM
Bc you know all about me....lol. Its not for me bc I don't just shell out cash for something I believe is a bit overpriced? and i just read an "ok" review? Some people are conscious of their money and don't just hand it out. lol
Old 06-18-2017, 11:09 AM
ah yes you're smarter than the rest of us...feel free to offer up a better solution...of course you won't.
Old 06-18-2017, 11:16 AM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Looks good. How much trimming did the adaptive cruise control cover require?
I wish Texas didn't require the front license plate, I'd like to install something like that.
Old 06-18-2017, 11:23 AM
17f250ford's Avatar
17f250ford 17f250ford is offline
17f250ford is starting off with a positive reputation.
I like it it looks really nice man!!
One question is it "legal" NOT to have a liscense plate on your front bumper in texas?
Note: i see your from houston
Old 06-18-2017, 11:30 AM
bridge's Avatar
I live in the 'burbs of Houston. You don't have to have it on the bumper, but it must be visible on the front of the vehicle. Not having one is illegal but won't normally result in getting pulled over by itself, just and additional violation tacked onto whatever the cop pulled you over for, like speeding for instance. However, it really t's off the speed trap cops because they aim the lidar at the front license plate to get a good speed reading.
Old 06-18-2017, 11:34 AM
17f250ford's Avatar
Yea i get you man
The led light looks really nice i like it more than the one with the mounted bracket on top of the bumper.
Ill probably get it and hope not to get pulled over
Old 06-18-2017, 11:36 AM
Woodhack's Avatar
Woodhack Woodhack is offline
Woodhack is starting off with a positive reputation.
bushpilot,
How did you mount it to your truck? Close up pictures please.
Old 06-18-2017, 11:42 AM
Quote:
I didn't trim much - a little off the side/flat above the left mount/screw, I probably trimmed more than I needed even at that....Ill see if I can't get a picture of it later.
I havent run a front tag on anything I've owned in over 30 yrs - I've been stopped a couple of times (3 that I can recall)...written warnings 2 of those times.
I got my 1st and only (front tag) ticket a couple yrs a go (didn't write me for the considerable speed I was going)...I (temporarily) resolved the front tag issue (provided photographic evidence) and the (non moving violation) ticket was dismissed.
Grill and Rear LEDs ckrampota1 2017+ Super Duty 23 09-15-2017 02:15 PM
Different SIZE Spare bushpilot 2017+ Super Duty 34 09-13-2017 04:45 PM
HELP - HellWig Fit Problem bushpilot 2017+ Super Duty 14 06-17-2017 08:15 PM
Hello from NW Houston bushpilot Texas Chapter 3 05-04-2017 10:51 PM
Splash Guards (aka molded mud flaps) bushpilot 2017+ Super Duty 12 04-22-2017 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
