Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Want to add Power steering to 1976 F500 Flatbed
Old 06-17-2017, 09:05 AM
waylotul's Avatar
waylotul
waylotul is offline
Cool Want to add Power steering to 1976 F500 Flatbed
I have an uncle that is asking to help him find parts to add power steering to a 1976 F500 dump truck. We both assume that it came with this option. I need some help locating the correct parts for the conversion. I figure I need a gearbox, pumps hoses and a brackets. Maybe some fabrication. ANY help is appreciated. Thanks.
Old 06-17-2017, 09:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
P/S parts are the same 1973/77 F500 & 1973/78 F600/880, but where you will find all these individual parts, I dunno, because all are obsolete.
You'd be better off buying one of these trucks with P/S, then removing all the parts.
1979's came with different V8's (370/429) than 1973/78 (330/361/391).
Old 06-19-2017, 02:19 PM
waylotul's Avatar
waylotul
waylotul is offline
So do I need to swap out the gearbox as well and do you think I need a new steering column as well?
thanks,
Old 06-21-2017, 09:19 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
Steering column... no
Power steering box.. yes
Pitman arm.. yes
Power steering pump.. yes.. but here you have lots of options.. make your own ps bracket or adapt one.. use a saginaw pump.. or find a ford (good luck there)
On one my f600's I brazed fittings onto my own PS lines to adapt to standard length hydraulic hoses for easy replacements
I am scheduled to get several F500/F600s next month to add to my collection.. one or two of these will be parts trucks and may have power steering
Please contact me later in July and Ill know if I have everything you might need
Old 06-22-2017, 05:11 PM
larrybird33647's Avatar
larrybird33647
larrybird33647 is offline
Sorry to butt in but I need some steering parts for a 1972 ford f600, is this year different from the 73-78 stuff?
Old 06-22-2017, 06:12 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
See post number 2 above.
I suggest you start your own thread and include your VIN, and all the info off the warranty plate on your driver door. And what parts you need.
Old 07-02-2017, 02:34 PM
hillbillyk's Avatar
hillbillyk
hillbillyk is offline
Just go to your local junkyard and look for some of these trucks, power steering was a common option. I have sold setups out of them before, pump, brackets, pulleys, box, and everything. I have some setups in Northeast Maryland if your close, not really worth shipping it all. Very easy swap. My 75 f500 has manual steering and it works great, never had any reason to change it, but it only has 7.25-20 tires and a 14k gvwr
SteveEford1
11-23-2010 12:52 PM
abnjumpmaster
01-31-2009 10:04 PM
labsnfords
10-05-2007 01:55 PM
Justin W
06-17-2005 10:56 AM
kkoles2000
08-11-2003 05:11 PM
Quick Reply: Want to add Power steering to 1976 F500 Flatbed
