Black primer on new body panels remove or keep?
Morning guys,
I did some specific searches but did not find a thread asking about the black primer that comes on some of the body panels. I removed it everywhere I had to weld. Do you guys remove all the black primer or leave it? Does anyone know what kind of primer it is? I read somewhere it was epoxy but find that hard to believe.
There are fairly decent e-coatings on quality panels and there are any number of spray coatings that "look" like e-coat but are only good for keeping flash rust off the panel. As a rule of thumb, I sand the black coating down to the metal in one area of the panel...if the coating feathers out then the adhesion is good. If the coating goes from black to silver immediately then the coating is flaking and should be removed.
The new front panel for my truck bed came with good primer on it.
Truck bed front panel
It looked like black ecoat powder was used but not sure as acetone did not touch it and it was flawless. I did rough up the surface with 400 grit before painting it.
jimmystoys
02-05-2018 04:50 AM
buffalostagecoach
04-18-2013 07:38 PM
