Hey guys, at start up whether the engine is hot or cold the engine will run at a high rpm's for a minute or so then comes down to 700 ish rpms. Is this normal or do i have something that has gone out? There are no codes. Thanks for the input. Really this is not a big deal. Just wanted to see if there is a fix for this.
Could it be the IAC? Would it not throw a code if it is?
Started driving my son's 98, 5.4L, F150 a couple weeks ago due to playing musical cars at my house. It does the same thing, but per the tach, it hits about 1575 to 1600 rpm's. Son said it has been doing this for quite some time. I don't drive it very often, but I don't remember it doing that. No other codes or issues. Will follow this thread to see if you find anything 02GPS.
