Too toss the POS E4OD or to keep it - Ford Truck Enthusiasts Forums
Old 06-16-2017, 09:55 AM
garrettsf250 garrettsf250 is offline
garrettsf250 is starting off with a positive reputation.
Good morning fellow Ford fans. Alright here's the deal. Had a tranny problem. Torque converter kicking in and out ended up being a 3rd brake light lol. Now my problem is the the when cold shifts absolutely phenomenal extremely smooth and strong through the gears. But once it reaches operating temp the tranny shifts hard, letting off throttle almost makes the truck stutter there's no loss of power. my fluids are full but dirty replaced the fluid and filter about a month ago maybe 2. im beginning to think it might either be losing pressure to shift if something I honestly have no idea.
ANY HELP WOULD BE GREAT. Unless you guys think I should just replace it with an upgraded trans 😂
Old 06-16-2017, 10:08 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Mark, our E40D expert, will most likely weigh in on this thread. I had a ton of problems with mine. I burned up two of them until I spent the big bucks on a John Woods trans. But I tow heavy and don't want to shift with 17K behind me.
Old 06-16-2017, 10:52 AM
Quote:
very cool hope I hear from him soon
Old 06-16-2017, 02:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Does the OD OFF light work? Has it been flashing?
Old 06-16-2017, 03:35 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Mark does the PCM use trans temp for shifting strategy?
Old 06-16-2017, 04:57 PM
Quote:
no it has not
Old 06-16-2017, 06:35 PM
Quote:
Yes it does.
Quote:
Originally Posted by garrettsf250 View Post
no it has not
No it has not what? I asked two questions, you gave one non-specific answer.
Does the light work?
Old 06-16-2017, 06:48 PM
Yes it does.
no it doesn't flash and yes it works
Old 06-16-2017, 07:59 PM
If it is losing pressure the shifts will get very long and soft, they won't be harsh.
How much fluid did you change?
Old 06-16-2017, 08:23 PM
I changed all the fluid in the transmission but not in the torque converter
Old 06-16-2017, 08:34 PM
green_95 green_95 is offline
green_95 is starting off with a positive reputation.
Scrap it. Do a zf 5 speed swap. I did mine about 2 months ago, and ain't looked back. I love it. More power and a ton better for pulling. You can really feel the torque.
Old 06-16-2017, 08:48 PM
Quote:
sure I'll do it if you wanna come do it lol. To many thing I'd have to adjust and make fit. If I went to go scrap it I'd buy and after maket transmission
Old 06-16-2017, 09:23 PM
z31freakify's Avatar
z31freakify z31freakify is online now
z31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to all
Where is the transmission temp sensor at Mark?
Old 06-16-2017, 09:29 PM
So you changed about half of the total fluid in the trans.
I recommend changing it again. This time drain the pan AND the torque converter, or follow this: https://www.ford-trucks.com/articles...-transmission/
Quote:
It's located on the solenoid body inside the pan.
Old 06-16-2017, 09:50 PM
Thanks Mark, is it something that can get replaced?
2003 F-350 6.0 tranny acting up Nichole Campbell 1999 to 2016 Super Duty 6 11-03-2017 12:10 PM
Ranger 5 speed manual transmission noise Bob Savage Ranger & B-Series 10 09-04-2017 07:29 PM
A4LD SHIFTING ISSUES--HELP 78 Ford F150 460 Explorer, Sport Trac, Mountaineer & Aviator 0 07-23-2017 12:25 PM
Clink Noise Loki86 1987 - 1996 F150 & Larger F-Series Trucks 1 11-06-2016 08:38 PM
Transmission issue jed1894 1999 - 2003 7.3L Power Stroke Diesel 8 01-13-2016 09:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
