Is the Juice worth the Squeeze?
The T-500 was pre-emptive. I had 4 oil leaks last summer in the HPO system. I knew that at least one of the seals/plugs was leaking on the pump itself so I sent it off to have it rebuilt while I was elbows deep in the valley for a couple of weeks. I was going to either tear the HPOP apart and re-seal it or have Joey make it into a T-500. I opted for the latter.
Brian - Injector wise: exactly where I'm at too... and have been doing on these threats you'll have to keep me posted on results
haven't noticed any oil leaking from the hpop but I do have some oil soak down the back passenger side of the block to the started / tranny lines - not sure what that's all about but at some point I'd like to plug that one up - it's been there isn't I bought her
Karlow,
I have not witnessed one personally but as I understand it they rev the engine up to ~2 to 3K for a period of time (seconds I think) then release the throttle and quickly floor it again momentarily. This to check for excess smoke. It is done three times with the first one being a "freebie". Sounds like a good way to do some damage to me.
I'll check that out today - since I'll be poking around under the hood. My mechanic friend seems to think it's " the big allen head oil plug at the back of the block that needs to be snugged down" ?? We'll see...
I've had my eye on Idaho for a couple years now - if I can talk my boss into letting me work remote (I'm a produce salesman), all would be right in the world...
Pkupman82
19
11-22-2017 06:42 AM
powerstroker100
04-13-2010 10:54 PM
