Water Pumps in 2017??
Guess I'm going to have to remove my water pump, which there is no problem with one more time so I can address the leak at the top where the pump goes aganst the front cover.......I did this about 5 years ago for the same reason and installed an AIRTEX pump which everyone said who supplied the pumps to Ford originally.....
I have replaced my pump twice since the original, same problems with both.....
I have never used any sealer, silicone, permatex ANYTHING......
May be thats my problem......this time I'm going to unless you guys say no....
I've lived with this stupid leak for 5 years now and just tired of it.....
So, where do I get my LAST pump-by LAST I mean one that will last me for a couple hundred thousand miles???
The last Airtex that I installed I got a seal right from International for it and used that.......
I dunno.....Thanks for any & all suggestions guys!!
I ran through two Airtex pumps. My OEM lasted 180,000 with gold coolant and all the casting sand before my first complete flush. The best I get out of the Airtex is maybe 75,000 running ELC with complete flushes. I went with NAPA this time. Time will tell how it compares. Side by side and weight, they are identical.
I can say i will never buy off brand water pumps any more. I have a thread which id have to dig for explaining my issues. Nedless to say i was getting mine from napa, car quest, and advance. I was getting 15k to 50k out of them. One lasted 10k. I have flushed the system 2x during replacements, replaced fan fan clutch pulley and t-stat. Im also running a coolant filter which gets changed every 20k once a year.
Finally went with a OEM pump and got about 85k on it so far. I compared the oem with several pumps i went with via photos and weight. Major difference in weight and castings.
I learned my lesson with that alone with power steering pumps and other things. Nedless to say I'm an oem guy. The little extra in price is well worth the headaches of tearing something back apart, returning it and re installing something again only to repeat that process over again.
OEM ALL THE WAY !!!!!
May be RiffRaff is having them made.....
Certainly no offense to Clay, but this is the last pump that I personally going to replace on mine and I expect it to last over 200k miles.....
As late as 2012 folks are saying that Airtex was the original manufacturer to Ford at least for the pumps, thats what 99% of everyone here at the FTE was saying 10 years ago as well.
Which water pump? - Diesel Forum - TheDieselStop.com
Around the edge of the entire oring. It appeared the groove the oring fits in was not accurately cut, so the oring was sitting a little deeper in areas. We used black high temp rtv.
