Water Pumps in 2017??
My airtex lasted 40K before leaking out the seep hole. Maybe I provoked it a bit because I was running my ELC too lean (small leak on t-stat made me add water a couple times) and my coolant definitely had rust in it. Bought a motorcraft (felt a bit heavier?) and put a bead of high-temp red rtv around the gasket. Not a drop so far. Oh, and I put a small bead of rtv around the airtext also which didn't leak itself. When I pulled the airtex, i noticed the t-stat gasket rolled during installation which caused the leak there. Hopefully the thorough flush, second new $90 batch of Rotella ELC, new motorcraft radiator, and hoses will keep me on going strong (at least on the cooling side) for a while.
Final Charge ELC coolant and the fact that I've had a coolant filter in my system for a long time so there should be no casting sand left in it to hurt the seal.
That's because branding.
Once upon a time, Ford had a contract with a company to make their water pumps and brand them as "Motorcraft". Years later, that contract expired.
Do they come with a Ford logo? Absolutely not.
Are they a Motorcraft part? Nope because that's a brand name and you didn't buy it from Ford.
Is it still the same as the OE pump. Yep.
Is that company Airtex? OMG NO, WHERE DID THIS RUMOR COME FROM??
Airtex is an aftermarket manufacturer who makes product based of OE design. IE: Dorman
"All Airtex water pumps match Original Equipment (OE) manufacturer specifications with no inferior material substitutions. The OE-quality water pump components include: pulleys and hubs installed with data-collecting automated presses; precision-ground and permanently lubricated unitized bearing assemblies; mounting surfaces machined to strict tolerances for proper sealing; impellers engineered for maximum coolant flow; and unitized seals to provide exceptional protection against leakage and contamination.
Also, about the China thing:
Parts are assembled in North America and the housings are forged overseas. Obviously, a big ole' CHINA stamp looks bad but it's just the reality.
HOLLA,
Gettin' paid for typing this from my
iphone 4 samsung NOTE 7500 computron!
Consider using Aviation Form-A-Gasket on the mating surfaces, and in the o-ring groove, too. It's good stuff, and has served me well for over fifty years.
All surfaces first have to be clean and dry!
Another product that I have seen used with a lot of success is 3M Super Weatherstrip Adhesive (comes in both black and yellow), but it can be "stringy".
I find the Form-A-Gasket stuff is a lot easier to work with. Comes in a can with a brush-in-the-lid. Reminds you a little of thin tar (but it isn't).
Your tip for the day from an old fart.
Pop
Pop
BlackJeep
04-30-2008 06:06 AM
