2011 F-250 Gas Emissions Fail
First time here! Thanks for an awesome forum. Just bought a used clean title 2011 F-250 6.2l gas. First Ford Truck for me. Question: How do I get this to pass emissions? I keep reading about diesels, but I don't know if the same procedures are done for the gas engine. Local mechanics say to do drive cycle then bring it back for testing. I cannot find accurate steps for drive cycle. Recommendations or thoughts would be welcomed? Also, I commit to give feed back after completing recommendations.
to pass emissions.. no check engine light..= PASS.
but they do not look for the light.. they plug into truck computer.. for Pass.
No errors or failed codes...
I have NO idea what your mechanic is trying to do.
retired mechanic.
In order to pass the computer check the engine has to have had a certain set of conditions occur since the last time the computer was reset (for example, by disconnecting the battery). Usually it's some number of start/drive/heat up cycles, along with a certain number of accellerate/decelerates and a time or mileage quota.
So basically get in it and drive it for an hour or two, including some stop and go traffic as well as some highway. Then the engine computer can report its status as 'valid'
NinthGenF-SeriesOBS
13
04-02-2016 01:36 PM
