F1 front and rear shocks
I would suggest Bilsteins. They are a quality shock and a couple of different shops I've dealt with recommend them. I have purchased them for my 48 F1. However, I have not yet installed them. They can be pricey, but you get the ride for which you pay.
Posies carries them and you can find them for your truck on page 39 of their catalog. Catalog here:
http://www.posiesrodsandcustoms.com/...OOF-4-4-14.pdf
Price sheet here:
http://www.posiesrodsandcustoms.com/...t-Dec-2016.pdf
Good luck in your parts search. Stay safe out there.
Philip
Price sheet here:
Philip
Personal opinion, there is so much friction in the stock spring packs that there is inherently a lot of damping. I can't imagine the stock suspension "porpoising" down the road with NO shocks, particularly the rear. If you are using Posie's there is probably a noticeable difference in shock performance.
As I recall you are going with the 8-leaf front? I have that too, plus large heavy tires. I measured eye-to-eye and found the Gabriel replacement shocks would be near the limit of their travel in the at-rest position, something like an inch and a half of extension left. (because the front end sits higher) I ended up with Gabriel 77405 Max Control shocks. They are quite a bit larger diameter than stock, have plenty of travel, have a nice dust boot, and aren't super expensive. For Gabriels they seem to be decent quality.
Be sure to check that your brake hose at the fronts isn't what limits downward movement of the axle! When I was installing these, I was shocked to see that the hose was stretched tight! I had some made up with an extra inch or so length.
My F3 came from the factory without rear shocks. I put some on after getting the mounting brackets off a 48 F2. I don't notice any difference, even with a load.
I also "assumed" my stock, original Ford front shocks would be empty shells after all these years. I took them off to put some Bilstein's on and they were still good! Well they seem to be ok. They do not leak and they dampen any movement. I did not throw them away. Some paint and new bushings and they will probably be ok.
The high dollar Bilstein shocks don't seem to make a noticeable difference to me. On my stock suspension anyway.
Like Phillip I went with Posie's recommendation of Bilsteins in the front since I have their Dual-Flex springs on the front and Super Sliders on the rear. In the rear I stayed with Gabriels not quite as good as what Ross has. The change in ride is significant over the old springs and standard shocks that bounced the truck around so badly that a brake shoe keeper fell off and rattled around in the RF wheel.
hulleywoodworking
02-12-2020 09:25 AM
Don Vito
08-14-2016 11:30 AM
al37ford
08-04-2009 11:08 PM
