Plastic in turbo feed line
2005 f350 6.0 is the truck. Was getting underboost codes and then turbo started making noise like the turbine was hitting the housing. Assumed the underboost was from sticking Vanes but I'm thinking not now. Pulled turbo out and found this chunk of plastic in the oil feed hole. I had this truck apart to do stc fitting previously. Did I just drop this in here or is something from the oil filter housing blowing apart? I didn't recognize the piece at all. Thanks guys
Okay I'm a moron. I was looking at the tabs on the side of the stand pipe. The bypass ball is missing and someone jammed one of those white clips from using aftermarket filter in the top. I've always used motorcraft filters and cap and didn't pay much attention apparently. Didn't realize aftermarket filters would make you do something so stupid... Get a new stand pipe coming and live and learn I guess haha. Thanks guys
BUT
03-28-2010 12:19 PM
caveman 53
09-16-2009 07:06 AM
