My fire extinguisher saved my truck
Well this is a timely post. Jason really glad it went as good as it did for you and thanks as always for sharing. My neighbor works for a commercial sprinkler fire system company and he just gave me a couple of extinguishers a few weeks ago. As usual I've procrastinated in putting one of them in the truck, the other is for the shop. I think tomorrow I will work on getting it mounted.
I've been carrying one of those little 2 lb bottles around in the back of the truck for a while but to be honest I don't know if it's even any good doesn't even have a gauge on it. I think these will work much better.
If you don't already know, that Halon extinguisher is dangerous. It removes the oxygen in the air in order to extinguish the fire. We have them for the data floor at work. You can become asphyxiated in a room if you don't get out in time. I think an ABC extinguisher would be the one I choose (I do get the free thing though).
Good luck!
Bill
The little disposable extinguishers sometimes have a 'button' on them someplace for testing pressure. You push it in, and if it pops back out - it's still 'good'. This doesn't help the caked powder problem, but you can dispose of any that don't pop back out!!
This is what was in my truck. It's a BC type (with gauge). There are a few of these scattered around our house as well.
A few years ago, I took a couple of 'aged' cheapo extinguishers and did some practice/training with my boys. We lit a bucket of diesel on fire and let boys take turns putting it out. (P.A.S.S. method). We also talked about what level of fire they would even attempt to put out with this type of extinguisher.
For God's sake, Halon has been banned ostensibly because of Ozone depletion. It is probably the best fire extinguishing "stuff" around. Sad. It might be "dangerous" but then, so is FIRE. Try to keep some perspective.
Very true. As a veteran I found that the U.S. Army is replacing their Halon systems. Also, the U.S. Navy would have oxygen canisters and masks in compartments protected by Halon.
Good idea. I have a cheapo fire extinguisher that should be replaced. I should teach my daughter how to use it the next time I burn brush on my property.
Paul,
Good luck!
Bill
Good luck!
Bill
Halon bottles will be in the truck and garage(outside use). The little ABC bottles like Jason's picture in the boat(small enough to store) and kitchen.
I like Jason's idea of a training session with an old bottle. May try it with the little one.
Not because they want to, but because it's been banned. The Ozone, don'tcha know. But, there is nothing currently available that comes even close to its effectiveness. Aviation is exempt from the ban.
Brandon, you want an A,B,C fire extinguisher. That means it's good for all types of combustibles (except metal). I think I am going to order a 5lb for my classic Oldsmobile and whatever truck I buy. Here are some options:
https://www.summitracing.com/search/...2%2B4294843673
#28
#29
I just made the move up to ND and had an out of date but still charged 5lb extinguisher my old job gave me when they upgraded. It was in the cab but not SUPER accessible. I need to figure out some way to have it accessible but out of the way in case of something like this. I have seen the trucks in the oil field that have them mounted on the headache racks, but I have neither the desire to have mine exposed to the elements nor a headache rack to mount it on so that is out. Maybe when I get around to making my high lifter jack rack in the bed, I can incorporate a couple quick release mounts for an extinguisher.
Thanks for sharing your story! Hopefully it will save someone else's truck by spreading the word to carry extinguishers in every vehicle.
#30
I had a small extinguisher in my truck whose 'charge' needle had just descended into the 'red zone'. I emptied the extinguisher outdoors, and found that probably 1/3 of the powder was still inside. Not enough gas to expel the powder.
The takeaway is this: if the needle isn't in the green zone, replace it!
