1996 Ford Brinco with 5.8L stalling. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page > 1996 Ford Brinco with 5.8L stalling.
Old 06-11-2017, 01:19 PM
MISHAF
MISHAF is offline
MISHAF is starting off with a positive reputation.
Need some help. My daughter. Bought a 1996 Bronco. The Bronco will start and then stall. Or, run for a bit and then stall when trying to back out of the driveway.
Things replaced already:
ICM
wires
coil
both front O2 sensors
trans filter
I tried to use a code retriever but all I get are incomplete tests.
any ideas?
Old 06-11-2017, 11:26 PM
grumpin's Avatar
grumpin
grumpin is offline
grumpin is gaining momentum as a positive member of FTE.
That's frustrating, you need codes. The EGR can cause it to stumble when taking off, but usually doesn't kill it in my experience. I would try a different code reader.
Old 06-12-2017, 11:45 AM
Redark1
Redark1 is offline
Redark1 is starting off with a positive reputation.
It being a 96 its probably OBDII, you need a code reader for that.
is there a CEL on when its running.
Old 06-14-2017, 11:08 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Based the OP's first post statement "I tried to use a code retriever but all I get are incomplete tests." that implies they have the proper code reader and the only codes indicate the drive cycle monitors are not fully completed.
It's time to check the fuel pressure IMHO.
Pkupman82
01-29-2017 08:30 AM
Samuel Poynter
01-15-2017 08:13 PM
Hummer_Hogs
Bronco II
01-10-2017 02:30 AM
adamp29
11-21-2016 10:09 PM
dougal3434
09-22-2016 01:10 PM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
