2WD Lower Valance on 4x4 - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-11-2017, 11:07 AM
brentadams646
brentadams646 is offline
brentadams646 is gaining momentum as a positive member of FTE.
Super easy swap, this is the way the trucks should look coming from the factory. I understand the reasoning of the larger front valance, but this just looks better.
OEM 2WD Lower Valance - PN: HC3Z-17626-AD - $54 from Tasca Parts
Old 06-11-2017, 11:11 AM
shortride's Avatar
shortride
shortride is offline
ididmyduty
shortride has a very good reputation on FTE.shortride has a very good reputation on FTE.shortride has a very good reputation on FTE.
The URL's don't work for me.
Old 06-11-2017, 11:12 AM
brentadams646
Yea not sure what was wrong with them. They should be updated now.
Old 06-11-2017, 04:52 PM
No1Hookman's Avatar
No1Hookman
No1Hookman is offline
No1Hookman is starting off with a positive reputation.
And to think, when the '08s came out, a lot of folks were putting job 2 valances (longer like the '17s) on to get a little better fuel mieage. Fuel was over $4 at that time. My, how things change.
Old 06-11-2017, 05:13 PM
brentadams646
haha yea I haven't paid for fuel since 2012 (company fuel card) so it doesn't really bother me. I usually chunk the oem parts once I swap them out but I'll hold on to the 4x4 one just in case my fuel mileage drops significantly.
Old 06-11-2017, 05:35 PM
BADAS03SVT
BADAS03SVT is offline
BADAS03SVT is gaining momentum as a positive member of FTE.
putting that on my list....looks better
Old 06-11-2017, 05:37 PM
Tex68w's Avatar
Tex68w
Tex68w is offline
Tex68w is starting off with a positive reputation.
OP, let us know how much your MPG drop.
brentadams646
this lower valance and the power running boards really help the look of the oem stance. Still needs a leveling kit and larger tires.
Old 06-11-2017, 08:09 PM
Litre's Avatar
Litre
Litre is offline
Litre is starting off with a positive reputation.
2wd valance on mine as well. If there's any mileage loss, it's to the tune of .1mpg in my case, but that's minimal enough to be anecdotal and/or a function of a leveling kit I installed at roughly the same time
Old 06-11-2017, 09:05 PM
wfedwar
wfedwar is offline
wfedwar is gaining momentum as a positive member of FTE.
I need to do this. I remember when I first saw the 4x4 valance, I thought it looked really strange.
Old 06-12-2017, 12:36 AM
RainDesert's Avatar
RainDesert
RainDesert is offline
RainDesert has a good reputation on FTE.RainDesert has a good reputation on FTE.RainDesert has a good reputation on FTE.
Well done Brent. The first mod I did to my '17 was remove the 4x4 valance. I am thinking about ordering this one, thank you for the tasca part number. Reps sent.
Old 06-12-2017, 12:51 AM
OR2BAJA
OR2BAJA is offline
OR2BAJA is gaining momentum as a positive member of FTE.OR2BAJA is gaining momentum as a positive member of FTE.
Looks so good.
I ordered from Tasca and had to cancel my order 54 for the valance plus 14 dollars for the part cool! Well the emailed me after a couple of days and said that they made a mistake in the shipping calculator and I owed them 30 something more. So a 50 dollar part and 50 dollar shipping, nope. Well I re ordered from varsity ford, no problems then here we go again... they blamed it on ford for incorrect dimensions. It's 90 bucks from the local stealership so I am a little bummed to say the least.
Old 06-12-2017, 07:27 AM
shortride's Avatar
shortride
ididmyduty
Did you have to remove the bumper to install the panel? Also, did it use the existing mounting holes and hardware?
Old 06-12-2017, 07:33 AM
brentadams646
You don't have to remove the bumper. It uses all the existing hardware and is a direct replacement. There are two "claw" shaped things that are bolted to the bottom of the frame-rails of the 4x4 trucks. I believe these are to keep the higher trucks from running over smaller cars. They need to be removed otherwise you'll see them hanging down below the shorter valance.
Old 06-12-2017, 07:41 AM
brentadams646
Crazy! I paid around $140 for the below;
Quick Reply: 2WD Lower Valance on 4x4
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
