CrownVic with FE question
Old Jun 10, 2017 | 10:08 PM
Riskit's Avatar
Riskit
can anyone out there tell me the space you have under the oil pan on a FE motor after you convert to the crown vic front end? Does it get tight or open it up a bit. I understand you make your motor mounts and can move it up and down but in normal fashion and placement what do you end up with?
Thans for any info
Old Jun 11, 2017 | 04:12 PM
wa-sleeper's Avatar
wa-sleeper
check out apocolypsbob on youtube. he has a series on the cv front end swap and i think his was a 390 as well a ton of good info from his. take a pin and paper and take notes
Old Jun 11, 2017 | 06:38 PM
flowney's Avatar
flowney
As the video will make clear, you will need to source a rear sump oil pan and related parts (sump, dip stick, etc.).
BEN WHEELAN
32
Dec 8, 2015 09:36 PM
ApocalypseBob
May 9, 2015 10:11 AM
DirtyCustoms
Mar 19, 2012 01:18 PM
66MercMan
Mar 7, 2005 09:56 AM
ford390gashog
Jan 21, 2004 08:58 AM
