Where would the remote unlock module be on a '08 F550?
I bought a '08 F550 that has electric locks and a keypad on the door. I would like to see if there is a remote unlock module so I can unlock it with a key fob. I only received keys to this truck so I am not sure if it has a module. Anyone know where it might be?
On an 08 Super Duty, the RKE functionality is integrated into the SJB, there is no separate module as there had been on older models.
Try putting the system into the fob-programming mode (instructions are probably in your owner's manual). If it enters programming mode, then it's ready to add new fobs.
Use a scan tool (or Forscan with appropriate adapter) to pull the data from the SJB's memory. There *might* be a label on the SJB with the factory default keypad code written on it. You'd have to do a visual on yours to see if there's a sticker or label.
how do I go about finding or resetting the door code on an older truck?
Zach1008
08-15-2018 09:04 PM
big orange beast
12-02-2011 06:29 AM
FordPowerStroke
03-26-2011 06:11 PM
