Oil pan drain plug leak?
I had a slow leak on my drain plug for the oil pan when I bought the truck. I thought that was a good time to find out my real world opinion on the Fumoto oil pan valve.
The Fumoto is overpriced and there are other options, but I received it as a gift and it has been great. No leaks, projected flow of oil when draining and can shut off flow and swap out containers easily.
It does dramatically slow down the time it takes to drain the oil, but I am normally not in a hurry those days anyway. A cold beer and I spend some quality time together with a bit of Waylon Jennings playing the background while waiting for the oil to drain.
The following users liked this post:
on
I did pick up a variety pack of fiber washers and such. I thought if I could find one that would be tight on the threads, I could use a copper gasket to squash and hold it fast...maybe
I didn't consider a damaged bolt as a possibility.
Sous- do you have the Fumoto 90 deg or straight down, or no nozzle?
I got the Fumoto with the nozzle thinking I'd hook tubing to it then into a container when oil change comes around. Turns out I can just set the gallon oil jug under it with about an inch of clearance. Turn it open, fill jug, rinse and repeat. Makes draining the oil super easy, but like Sous said, slow. Stock 4X4 and tires on mine tho, so if you're lifted or have 37s ymmv. Grab a jug and see where yours sits. As you know stripping that hole out can be very bad, so a Fumoto is a no-brainer to me.
Originally Posted by Sous
I agree sir, hopefully our paths will cross one day and the path can pause for a moment for a bit of reflecting.
Originally Posted by Supercab
I installed a blue colored composition type washer on my original drain plug at my last oil change about a month ago-its dry as a bone now & I've got 2 more in the package!!
I have used the same blue colored washer for 15 years. I may replace it at 20 years. Had problems with the copper crush washers at my first oil change, and went with the blue after that without any incidents.
