Oil pan drain plug leak? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-12-2017, 05:50 PM
johnsps250 johnsps250 is offline
johnsps250 is gaining momentum as a positive member of FTE.johnsps250 is gaining momentum as a positive member of FTE.
This one looks like it will work, always had good luck with stuff from McMaster Carr.
I've always had to replace the copper washer after a couple changes or it would drip. Next time I change the oil I plan to give this a try.
Link
  #32
Old 06-13-2017, 10:37 AM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
I don't know how much actually weeps out when I drive but there's always one drop clinging onto my drain bolt whenever I look under there.
This is timely since I am replacing injectors so I just ordered some (you have to order a minimum of 5). I didn't like the fact that you can't estimate shipping so see if it's going to be cost effective (you can call their customer service line though).
I like the Fumoto but I would always be worried of catching it on something and ripping it out (especially off-roading). Whether true or not I would always have that concern. So to get 5 of them for 1/2 the price of the Fumoto it's worth a shot.
Hopefully this is the solution to my issue. Thanks for the recommendation johnsps250. Reps sent!
  #33
Old 06-14-2017, 10:42 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Kind of odd that nearly every other fluid fitting on the engine has an o-ring seal, but not the drain plug . . .
  #34
Old 06-14-2017, 11:07 PM
countrycar's Avatar
countrycar countrycar is offline
countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.countrycar has a great reputation on FTE.
Quote:
Originally Posted by ExPACamper View Post
Oh well, if it comes with a washer and everything... LOL
I could also just weld that hole shut and poke a screwdriver through the pan when it's time to change oil. I could probably get about 12-15 changes out of a pan.
That's 3-4 changes a year, so about 5 years before replacing the pan. Hmmm...they're so "close"
LOL.....
I should look closer, mine is leaking but I thought that it was coming from my rear main seal. I changed the washer on the drain plug, but when the leak continued I assumed it was my rear main seal and not the plug. After reading this thread I need to take a closer look.
  #35
Old 06-14-2017, 11:41 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud of
Quote:
I have thought the same, but wonder if it is because it is taken in and out so often? I know o-rings don't typically do well being removed multiple times.
  #36
Old 06-19-2017, 05:02 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
I got tired of the Ford washer & put the GM 6.2/6.5 Diesel aluminum washer with, looks like high heat silicone bonded in center,I had a handful left from My GM diesel days,been using them for years on several applications,never had one leak even when reused several times.
  #37
Old 06-23-2017, 11:20 AM
ExPACamper ExPACamper is offline
Almost there
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Quote:
Got a part number, pic?
After all the time and money I put into the top end to stop leaks, it's crazy to see oil spots on the ground
Thanks!
  #38
Old 06-23-2017, 11:26 AM
Almost there
Quote:
Originally Posted by countrycar View Post
LOL.....
I sprayed and wiped the sides of the pan with brake cleaner, including the bottom down and around the plug.
When the plug was wet, but I could go all the way around the pan and feel dry, I put the gold star on the plug
There is one bolt in the pan that leaks a bit, too. I plan to pull it out, squeeze a little Permatex ultra-black into the hole (maybe into the surrounding gasket surface 1/8" or so around the hole), coat the bolt with the same, and reinstall and give it time to sit and cure before driving.
Might not get it all, but should really slow it down. As I mentioned above, I can still get a dry pan after sitting a while, but after driving and such for a bit, it's wet there.
  #39
Old 06-23-2017, 04:09 PM
Pikachu's Avatar
Quote:
True, but at least they're cheap
  #40
Old 06-29-2017, 12:27 PM
Thanks!
Sorry,I don't get on here as often during Harvest hours,GM p/n 14090908 it was used on 6.2 & 6.5 GM diesels I had both at one time,used these washers on several Ford & GM applications.
  #41
Old 06-30-2017, 02:58 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
I tried that once on another vehicle and ended up with a stuck bolt. It sheared off next time I was in there. I'd recommend some RTV around the head of the bolt, but not on the threads, and not in the hole.
  #42
Old 06-30-2017, 03:46 PM
Almost there
Quote:
Noted. Thanks for the warning
  #43
Old 06-30-2017, 03:48 PM
Almost there
Thanks! I now have 3 in my console
  #44
Old 07-09-2017, 02:11 PM
Almost there
Success!
Looks like the new gasket/seal did the trick
It was much tighter and I had to push and thread it on the bolt all the way before reinstalling the drain plug.
Thanks!
  #45
Old 07-09-2017, 05:51 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Agreed...
Where did you find this washer?
Bennett Auto Supply......I wish I still had the package with the part number for you.....
Front Gear Oil Leak ryanparhaniemi 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-24-2018 01:39 PM
Boost leak test biggdirty7.3 1999 - 2003 7.3L Power Stroke Diesel 42 12-25-2016 06:45 PM
Coolant leak ehask71 1999 - 2003 7.3L Power Stroke Diesel 9 11-18-2016 09:40 AM
Manual Steering box leak lalberts 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-04-2016 01:23 PM
leak Danny2016 6.0L Power Stroke Diesel 3 09-08-2016 06:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
