Sponsored by: Real Truck
Engine???
Old Jun 10, 2017 | 10:02 AM
BIGIRA's Avatar
BIGIRA
Engine???
Ok here goes I dive a 1999 f250 super duty with 5.4 it's automatic 4x4. I dropped my kids off at school and was headed home turned a corner when the oil/temperature light flashed and the truck just quit. I tried restarting it and it just clicked like the battery dead. Had my better half come and jump it. Did not work it would only roll about a half Revolution and stop. So we towed it home where I put the battery on the charger. Now I can't even get it to roll over. And yes there is oil and it did not over heat.
Old Jun 10, 2017 | 10:25 AM
seville009's Avatar
seville009
I'd start with a good battery just to eliminate that since it's a simple step. Maybe use the battery in your other car just to try it. If it does start right up, check what the charge is with it running to make sure the alternator is ok. If not, shut it off so you don't kill the good battery.
Old Jun 10, 2017 | 11:32 AM
BIGIRA's Avatar
BIGIRA
Definitely not the battery. Checked the starter also starter tests good.
Old Jun 10, 2017 | 01:31 PM
alloro's Avatar
alloro
The engine locked up due to a loss of lubrication. Even if the oil level is up there, the pickup tube could've clogged or the oil pump could've failed. If you want to verify if the engine is locked or not, put a big ratchet and socket on the front crankshaft bolt and try turning it manually.
Old Jun 10, 2017 | 01:35 PM
BIGIRA's Avatar
BIGIRA
Ok thanks will try turning it manually. Will let you know how I make out
Old Jun 10, 2017 | 02:23 PM
BIGIRA's Avatar
BIGIRA
Manual turning the crack was a no go. Where do I go from here???
Old Jun 10, 2017 | 02:35 PM
Chuck's First Ford's Avatar
Chuck's First Ford
you could NOT turn the crankshaft with a tool???
remove all spark plugs.. maybe hydro lock, coolant, fuel. try turning engine again.
engine is locked. !!
dropped valve,
broke a connecting rod.
remove valve covers and oil pan.. look for broken stuff.
then maybe remove cylinder heads.
Old Jun 10, 2017 | 03:01 PM
BIGIRA's Avatar
BIGIRA
In the process of removing plugs now. Thanks for the information. Will post when I finish.
Old Jun 10, 2017 | 06:27 PM
BIGIRA's Avatar
BIGIRA
Plugs out still can't get it to turn. Apparently not hydro locked. I guess tomorrow on to the next step.
Old Jun 10, 2017 | 09:14 PM
m-chan68's Avatar
m-chan68
Stupid question. Can you turn the engine backwards by hand?
Old Jun 10, 2017 | 09:39 PM
IslandBlueV10's Avatar
IslandBlueV10
Another thing I have read on this forum is that the A/C clutch seizes causing the pulley to stop and the belt stopping the motor. These people thought their motors locked up only to find once they remove the belt the motor turned over. Worth a shot.
Old Jun 10, 2017 | 10:32 PM
99f350sd's Avatar
99f350sd
Ya ac compressor... Check it.
Old Jun 11, 2017 | 08:13 AM
BIGIRA's Avatar
BIGIRA
Can't turn engine either way. will check ac compressor also
Old Jun 15, 2017 | 09:30 AM
phillips91's Avatar
phillips91
That happened to my ex wife's car. Oil pump broke and locked the engine up.
Old Jun 22, 2017 | 12:22 PM
BIGIRA's Avatar
BIGIRA
Ok apparently it was hydro locked. Turns over now. Put the plugs and coils back in and now it sounds like it not firing smh. I'm not sure what to try now.
