Can't figure out why water on pass. floor on my 98? - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-19-2017, 03:22 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
That drain clogging up is a common problem.
Try a coat hanger wire, or a piece of twisted strand, or woven strand flexible steel wire & twist/rotate it as you insert it into the rubber drain hose where it exits the firewall. Don't get crazy & poke or twist too hard, so as not to damage the drain hose, or its seal at the condensate box. Then run the ac & see if it'll drip out the drain.
Old 06-19-2017, 04:14 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Guitar string works pretty good for that. Maybe a low "E". Poor man's snake.
Old 06-19-2017, 07:28 PM
john jamieson john jamieson is online now
john jamieson is starting off with a positive reputation.
What about the wiper arm penetration?
Old 09-13-2017, 01:48 AM
gr93 gr93 is offline
gr93 is starting off with a positive reputation.
Temp tape the windshield trim see if water leak stops.
Mostly if leak is above rear view mirror area of headliner.
Been told by glass shops the windshield cab seam rusts out.
Have not figured out the floor leak..can see a trail made over the years..
Old 09-13-2017, 01:54 AM
1998Ranger25L153CID 1998Ranger25L153CID is offline
1998Ranger25L153CID is starting off with a positive reputation.
Amazingly it has stopped. The only thing I did was reglue the door weatherstripping that was lifting a little bit. Hopefully it will stay dry.
water comming in behind the dash on driver and passenger side tpolley 1987 - 1996 F150 & Larger F-Series Trucks 13 04-22-2017 02:26 PM
Water leak causing power liftgate to open itself and set off alarm Stevem8 2007 - 2014 Expedition & Navigator 12 02-10-2017 08:07 AM
Ranger pass middle of floor wet when raining 1998Ranger25L153CID Ranger & B-Series 6 01-07-2017 05:20 PM
Quick wiring question Jeff53 Excursion - King of SUVs 0 03-22-2016 04:05 PM
Waters in the wiring channel on the passenger side.. simonwim 1987 - 1996 F150 & Larger F-Series Trucks 21 01-12-2016 11:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
