2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Carli Suspension
Old 09-20-2018, 03:27 PM
homerj's Avatar
homerj
homerj is offline
Originally Posted by XXLTexan
So I pulled the trigger the pintop 2.5, steering stabilizer, and 17 inch wheels. Austin from CJC was a cool guy to work with. So do I get 37x12.50s or 13.50s? Would you 37 guys with stock radius arms chime in please? Also anybody know if a 37 spare will fit underneath? Thank you!
nitto ridge grapplers 295/65/29 is biggest you’ll get in there. It’s touching all 3 sides
  #332
Old 09-20-2018, 04:55 PM
wicked 2018's Avatar
wicked 2018
wicked 2018 is offline
wow the 29's must be huge! ;-)
  #333
Old 09-20-2018, 04:56 PM
wicked 2018
I ended up going with 37x12.5 on 17's with a 4.8 offset. With the radius arms I have I am sure 13.5 would work with some trimming. with my 12.5 I had to do zero trimming.
  #334
Old 09-21-2018, 12:42 AM
homerj's Avatar
homerj
homerj is offline
yea not much side wall but they look kool👊
  #335
Old 09-25-2018, 04:02 PM
XXLTexan's Avatar
XXLTexan
XXLTexan is offline
So I got all my stuff today and called the local tire shop to get the Toyo 37x12.50x17 for the truck and got shut down. Dude goes hey these are D rated you don’t want those anyway can’t get em try discount. So I call the discount tire I worked at 25 years ago in high school and they say yeah can’t sell em to you for your truck cause they came with load range E and I say look at the math the tires hold a ton of air and they said still no dice. So I can get 37x13.50s and run till I can afford a solution like radius arms or I can do 35s. Thoughts?
  #336
Old 09-25-2018, 05:34 PM
brandontolentino's Avatar
brandontolentino
brandontolentino is offline
D rated are just fine for 250's IMHO. I run D rated Coopers and they work for me.
  #337
Old 09-25-2018, 05:41 PM
wicked 2018
wow - i had zero issues at ameircan tires putting these on my 17" rims and them putting them on the truck for me.
  #338
Old 09-25-2018, 06:00 PM
LiquidSteam's Avatar
LiquidSteam
LiquidSteam is offline
Originally Posted by f350ktm
A 37 is not going up under without some significant modification.
I have a '17 F350 6.7, Pintop 2.5, Carli track bar, stock arms, full pack Deavers, and Firestone air bags over Daystar Cups. Method standards at +18, 18 inch Grapplers 37x12.5.
At 12.5 I have a minor rubbing at full lock, not sure what 13.5 might do.
My truck with this setup drives and rides like an absolute dream. I have no complaints, everyone that rides in or drives it is amazed, and my wife no longer wants to drive our Lexus.
I don't understand the hesitation towards the full Deaver/air bag/daystar combo other than the additional investment. To me it's very flexible. Excellent ride unloaded and loaded and towing my 5th wheel air bag setup is perfect.
ihave 37x11.5 r20 and a 2 inch bds level. There is 2.25 steering wheel rotations to full lock. I get a full 2 rotations before hitting the radius arm. Test it out and see if that is enough for you. Works fine for me and I live in a city environment
  #339
Old 09-25-2018, 06:08 PM
wicked 2018
Its all about offset. my 2.5" with 4.8" BS (0 offset) on 17's - no rubbing with toyo 37x12.5. I can see why a +18 would rub though
  #340
Old 09-25-2018, 07:48 PM
Undrgrndprdcts's Avatar
Undrgrndprdcts
Undrgrndprdcts is offline
How are you guys adjusting for tire pressures? Forscan?
  #341
Old 09-25-2018, 08:47 PM
wicked 2018
Yes. Easy change.
  #342
Old 09-25-2018, 08:48 PM
XXLTexan's Avatar
XXLTexan
XXLTexan is offline
I was not clear earlier when I was typing and driving around a job. I CAN get the 37 D rated at a few different tire stores I know with no problem but I think it’s not a good idea for only one reason...liability in the event of an accident. I have got sued in 2011 for an accident in my 07 Dodge that had a full KORE 3” lift rocking bill stein 7100 resi’s, full built Gorend trans motor work, programmed and studded 5.9 (man I miss that truck!)I had to explain every aftermarket item on the truck during the deposition in detail including load range rating of my 35x12.50 Toyo MTs. The other lawyer did a pretty good job asking questions that made these aftermarket parts kinda call my judgement into question. I did not have a trailer in the accident rather I was T boned by a beautiful drunk girl and she sued me. She did not win but it opened my eyes to the whole liability thing. If it had been my fault or at least partially my fault (in Texas you can share fault from 10% to 90%) and it would have involved extra weight (payload or trailer) and not enough tire on paper, I could have found myself in a tight spot. Especially if someone had been hurt. So are there any other 37x12.5 tires that are Great like the Toyota that are E rated? Holler if y’all know and thanks again!
  #343
Old 09-25-2018, 09:06 PM
wicked 2018
then get the E rated Toyo 37x13.5. Easy. If you’re worried. Make it work or keep it stock.
  #344
Old 09-25-2018, 10:26 PM
XXLTexan's Avatar
XXLTexan
XXLTexan is offline
This has been the very long way of asking if anybody knows of a 37x12.50x17 in a 10 ply E rating.
  #345
Old 09-26-2018, 10:24 AM
wicked 2018
When I was selecting tires - I looked but didn't have any luck. For sake of curiosity - I am interested to know this also.
That said - my Toyo's are rated at 3525lb (the E's are 4300). My rims capacity is 3600 lb (which even expensive forged rims top out at - https://www.innov8racing.com/product...k-studs-17x8-5) I feel 3525 is enough for the load capacities I run.
If I ever need more load capacity - I will just pop my stock rims/tires on for that trip.
Quick Reply: Carli Suspension
