f250 auto to zf driveshaft question
on
It's probably just a spacer to lower the carrier bearing down to prevent vibration. You can make one out of flat stock. Just get a magnetic angle finder from Harbor Freight and make the front and rear shafts as close to same angle as you can. This is a common mod needed when putting lift blocks on the rear axle.
One Sock
01-02-2014 12:19 AM
slowsix
06-10-2001 09:31 AM
