Anything for REAL fuel mileage gains - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Presented by the all-new Yokohama
Old 06-06-2017, 11:31 AM
cmscat50 cmscat50 is offline
cmscat50 is starting off with a positive reputation.
I just bought my first Ford truck. I've now owned Chevy, Dodge, and Ford. I believe I stumbled across a huge thread somewhere on this site regarding mileage, but can't find it now.
Is anyone doing anything that really works for increased fuel mileage. My truck is the 17 3.5 eco XLT super crew. I've done the air filter thing in the past. It probably only introduced more sand to my engines. Tire pressure, synthetic fluids, etc. I've done it all. I'd like to know if there's something pretty common that actually works to eek out that extra bit of efficiency.
Thanks.
Old 06-06-2017, 11:53 AM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Vehicle manufacturers have to meet federal CAFE standards and the rest of it, including pollution emission standards. If there was anything simple they could do to increase mileage they'd be doing it already, and they are.
Old 06-06-2017, 12:26 PM
rmccbride's Avatar
rmccbride rmccbride is offline
rmccbride is starting off with a positive reputation.
Best trick is to slow down.. And it's a free mod.... Just hard for some to do..
Old 06-06-2017, 01:07 PM
TJReams's Avatar
TJReams TJReams is online now
TJReams is gaining momentum as a positive member of FTE.
Back in the 70's one of the truck magazines did a real world fuel mileage test. They tried with a bed cover, with a topper cap, sealed the bed and cab together with duct tape. The best and biggest gain was simply folding in the rear view mirrors. the second best thing was slowing to 50 MPH. This was while the speed limit was a nation wide 55 mph!
I Promise you the same is still true.
Old 06-06-2017, 01:20 PM
Tedster9's Avatar
Supposedly, several cars of the 60s and 70s era got better fuel mileage at speeds greater than 55 mph, because of the gearing and/or engine RPM. This was pointed out during the debates leading to legislating a federal 55mph speed limit mandate but it didn't do any good.
Old 06-06-2017, 01:29 PM
brokenleg brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Your foot. and dont get in a hurry.
Old 06-06-2017, 01:35 PM
TJReams's Avatar
Quote:
This was actually false. I had a 67 Mustang coupe, 70 Mustang Mach 1 Fastback and a 65 Ford pickup, during the 70's. Everyone of them got better mileage by slowing down. All 3 had V8 engines.
Old 06-06-2017, 01:46 PM
Tedster9's Avatar
Well, that's 3 ... A lot of people swore up and down they got better fuel mileage at higher speeds because of the gearing.
Not saying this was true for all vehicles.
Old 06-06-2017, 02:07 PM
function12's Avatar
function12 function12 is online now
function12 is starting off with a positive reputation.
Loose weight and draft.
Old 06-06-2017, 02:55 PM
AbitaPro AbitaPro is offline
AbitaPro is starting off with a positive reputation.
You bought an ECO - BOOST engine, a good engine but two different concepts. For ECO part to work, tear everything out of your truck except your seat and seat belt and of course air bags, remove the bed and fold in the mirrors, then the key, put an egg on your accelerator pedal under your foot! If you break the egg, ECO test is over!
Now for boost, make certain everyone and everything is buckled down and strapped in tight, then drive normally, or mash the gas and get the boost!
Eco-boost is sort of like an amusement park roller coaster! The best of both worlds!
Old 06-06-2017, 03:38 PM
Delta Echo Delta Echo is offline
Delta Echo is gaining momentum as a positive member of FTE.
I had a 2000 Chevy pickup with a hardcover on the bed, but I don't think those even existed in the 70s. The mileage gain from the hard cover was impressive. But I got tired of removing it whenever I needed to haul something taller.
O.P.: keep tires inflated properly, and don't drive at highway speeds with windows open.
Old 06-06-2017, 03:48 PM
pikapp's Avatar
pikapp pikapp is offline
pikapp is starting off with a positive reputation.
Quote:
So true. Last year, took a 60 mile trip on two lane, speed limit was 55 and got near 28 mpg. Doing 67-68 on highway, best I get is 23-24. Still good.
Old 06-06-2017, 03:49 PM
It's not false. There are some vehicles that get better mileage at 65 than at 55, because the engine efficiency at it's 65 mph engine speed was better than at 55, enough to overcome the extra aerodynamic drag (or at least break even). It absolutely does happen, but those cases are more the exception than the rule (especially today, with greatly improved fuel systems and 10 speed transmissions). Engine efficiency is not linear through the entire range of RPM, largely due to scavenging effect (improved flow). Or in other words, more fuel is turning to work, instead of being wasted. In a best case scenario today, you might turn 40% of the energy in fuel into work (usually closer to 30%), and the rest is wasted. That is far higher than it was a few decades ago, but it still varies a lot based on engine speed and other factors.
Old 06-06-2017, 11:10 PM
Kingofwylietx Kingofwylietx is offline
Kingofwylietx is starting off with a positive reputation.
Mythbusters did a few fuel saving tests.
Drafting another vehicle helped. Free
Slowing down works. Free
For trucks, the tailgate replaced with a net was better than a tonneaua cover. I'm not sure if it's relevant with the newest truck designs. Tailgate down hurt fuel mileage.
Putting large dimples on the body, like those on a golfball was quite helpful. They covered the vehicle with a layer of clay and scooped out the dimples.
Race cars use belly pans underneath. You could try it with 1/8" plastic sheet.
Clean cars get better mileage than dirty ones, according to Mythbusters.
Driving at a steady speed and anticipating slowdowns helps. Free.
That's all I can think of right now.
Practically speaking, driving conservatively or buying a fuel efficient vehicle is probably the easiest way to get good mileage.
Old 06-07-2017, 12:24 AM
Tedster9's Avatar
Drafting works, but some people claim that then, the drafter takes a bit of a hit on his mileage.
Fuel economy scagwildcat 2017 Super Duty 1 12-06-2016 08:07 PM
Texaco Fuel Traildust 1999 - 2003 7.3L Power Stroke Diesel 10 11-17-2016 04:31 PM
2000 F250 Suggestions Alex Blake Modular V10 (6.8l) 9 09-22-2016 07:43 AM
1983 Ford Ranger Diesel bad fuel mileage rkim777 Ranger & B-Series 9 10-06-2015 09:33 PM
Alright, whats going on with my 6.0 TheFist 6.0L Power Stroke Diesel 17 03-15-2009 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
