Anything for REAL fuel mileage gains
#32
I'm surprised nobody mentioned a Gear Vendors unit:
Gear Vendors Under/Overdrive Ford Truck-Car-Van 2-Wheel Drive 4-Speed and 5-Speed Automatics.
While it might not help the OP. They apparently manufacture units for late model trucks. It might be worth giving them a call to see if they have a unit for the Ford 6R80.
It would probably help if you do a lot of towing and have a v8. EcoBoost is probably as good as you're going to get. At least until Ford releases their 3.0L diesel in 2018. I have a friend with the Ram 3.0L diesel in a 1500 and he gets 30+ mpg. However, these diesels are designed for fuel economy not towing.
Very, very pricey and they`ve been around for quite awhile.
#33
#34
#35
#36
#37
Thanks, the AOD swap is popular & will work. I would have to take out my original trans & cut my drive shaft. The AOD's from the 80's don't have any electronics except for the OD On/Off solenoid. I might do it in a couple years. This is the 50 year anniversary for Cougars so I need to keep it original as possible.
#38
People are not speeding to get to work early, they are speeding to get to work on time. Lol. I feel the same as others, Ford engineering spends way more money than an aftermarket company to have these trucks get the best milage possible. If a simple change to an intake resulted in fuel milage increase Ford would have implemented it already, they are under pressure to meet the tough standards from the government. Just my opinion.
#40
They would actually be in a much better mood if they would TRY to get to work at 7:50 or 7:55. And 99% of these folks also fly out the door at 5pm, or 5:01pm.
#41
True....but even all those late people are aware of that....they are just procrastinators. See, they have to be at work at 8AM, they know it normally takes 15 minutes....so they TRY to leave the house by 7:45. These are the folks that show up 5 minutes late every day complaining about the traffic or the slow driver they got stuck behind.
#42
There are probably things that could be done to increase mileage that the engineers can't do, because of the increasingly stringent emissions standards. Other than that, they work very hard using expensive equipment to make these things as efficient as possible within the design parameters of the vehicle.
Ram offered an Ecodiesel model named the HFE (high fuel efficiency) where they added active shutters in the grill and a bedcover. It was only available in a short bed, but I don't know if that was for weight savings or aerodynamics.
#43
#44
#45
Yeah, they were very efficient. But, if you read the rest of my post.......about the automotive engineers being limited in what they can do because of the restrictive emissions regulations. Obviously, all these smart engineers figured out the only way to provide a great product and meet the regulations was to cheat by not meeting those regulations. I don't advocate for dirty air, but VW and Ram are the poster children for what you can do if you only meet those standards some of the time.
I hope Ford can offer a great diesel without cheating. It's a great concept.
