caliper shims?
Old Jun 6, 2017 | 09:02 AM
PAwhiteboy's Avatar
PAwhiteboy
caliper shims?
I keep having to re-arch my caliper spring to take slop out of the top of the caliper. So much so, that I had to weld on a piece of steel to the "I" bar to keep the caliper in place. Now, it needs more bend to the spring.....again.
My friend was swearing they make caliper shims. I can't find any such thing and 78-79 dana 60 caliper mounts are not easy to come by nor cheap.
I got new calipers just four years ago
Anyone else run into this?
Old Jun 6, 2017 | 09:19 AM
HoustonDave's Avatar
HoustonDave
Excess slop? Wow, I have single piston calipers on my F100 and had to drive the wedges and springs in after carefully lubing 'em. Slop?
Old Jun 6, 2017 | 09:57 AM
PAwhiteboy's Avatar
PAwhiteboy
major movement. I can hear it and feel it in the steering wheel. Touch the brakes and its gone. The bottom of the caliper is tight and the top moves excessively (front to back). I can physically move it by hand and make a racquet.
Old Jun 6, 2017 | 10:20 AM
jconis's Avatar
jconis
I had the same issue on the passenger side. I used some shim stock I had. After cutting it into shape and sliding in the top gap the I beam and spring had to be pounded in. All still tight after 6 months of daily driving.
Jeff
Old Jun 7, 2017 | 07:00 AM
axelgawn's Avatar
axelgawn
Haha. I had the opposite problem it took me an hour to just try and get the passenger front caliper off. My problem is I need to replace the brake houses.
Old Jun 7, 2017 | 07:37 AM
good to doo's Avatar
good to doo
They sell new springs. Problem solved.
Old Jun 7, 2017 | 10:36 AM
jconis's Avatar
jconis
Yes they do, comes in a hardware kit for the front, also has New I beams too. Problem not solved .... Hence the shim.
Jeff
Old Jun 11, 2017 | 08:03 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Jeff
Exactly, fixed mine.
POPAJON
16
Jul 30, 2023 03:13 PM
Ford_Storey
Dec 17, 2013 10:40 PM
52caddy
Apr 29, 2009 08:53 PM
rustyoldford
15
Oct 9, 2007 05:15 PM
77f250highboy390
Jul 8, 2005 05:56 AM
