Does a 292 Y-block need an oil drain plug gasket?
I recently changed the oil in my grandpa's 63 F-100 which has a 292 Y-block and I noticed that there was no gasket or seal stuck to the pan or the drain plug itself and I'm pretty sure nothing fell out when I pulled the drain plug out of its last thread so I'm wondering if I should replace it with a gasket or not. Of course if I was going to install a gasket or washer seal I would have to drain everything back out into a clean plan but I can at least check to see if it leaks while the engine is running. I'm just not sure because if it doesn't need a gasket, I don't want to go through the trouble of installing one, but I'm not sure and I want to know from other Y-block guys that have worked on these before. Thanks.
There should be a fibre or plastic washer on the drain plug. What you could do, is drop the plug several threads and slip an o-ring or washer around it and tighten it back up without losing any oil or having to drain. Then the next oil change get the right plug/gasket. I guess, if it doesn't leak, you can wait a while.
I recently changed the oil in my grandpa's 63 F-100 which has a 292 Y-block and I noticed that there was no gasket or seal stuck to the pan or the drain plug itself.
I'm pretty sure nothing fell out when I pulled the drain plug out of its last thread, so I'm wondering if I should replace it with a gasket or not?
The gasket was originally made of fiber, Ford replaced it in 1962 with a nylon gasket. No drain plug used an o-ring.
ok after reading all these replies, and thankyou guys for the advice btw, i think i like the o-ring idea, because i have quite a few spare o-ring seals from briggs & stratton carb kits that i think will work, if not i guess i gotta take the plug out and do it the right way. anyways thanks for the help!
Are you 100% sure? I have different Y block pans with different size drain plugs. The pan I'm using now has a larger then 1/2" drain plug. Can't measure the thread size now but it has a head the uses a 1-1/8" wrench to remove and complete engine gasket sets include both size drain plug gaskets.
If the threads in the oil pan were stripped, auto parts stores offered TWO different sizes of oversized drain plugs that cut new threads in the oil pan.
Matt1966
17
12-05-2016 11:57 AM
FordTruckfan89
04-24-2014 09:29 AM
