460 eating bendix drive
#32
Well that first statement is a little off base.
Deck height changed *twice* and with the advent of external balance (D9TE blocks) the cylinder liners were were longer for more piston support at BDC.
Of course this means a late crank can be used in an early block but an internal crank cannot be used in a post '79 block.
But what does a block have to do with starter mounting?
Or the centerline of a bellhousing?
Was there an auto offered that didn't have an integral bell? (I think the only options were C6 and E4OD)
So, same starter, different centerline.... until the advent of gear reduction starters that had a solenoid instead of a bendix.
You cut the stock bell off and bolt this one on.
Now is the center line different between it and a stick SFI bell?
Dave - - - -
#33
I thought the suggestion was that the engine block was different somehow that would explain the different starter offerings. I misunderstood the writer's point.
Yes, I was speaking generally. Of course there were other block changes like 2-bolt and 4-bolt mains, but regarding things that would affect the starter, the blocks are the same. That was the point I was trying to make.
I see what your saying about the centerlines changing. The centerline of the "starter's Bendix" has shifted. That would explain why a 10 tooth starter and a 9 tooth fit the same engines. Yes - I like this explanation.
I don't like the "same starter" is used for 164 tooth flex plate and a 180 tooth ring gear. Are we sure about this? Maybe the gear mesh works out mathematically. Sure seems like a lot of knowledgeable people are/were saying there are two different starters - depending on whether Auto to manual trans.
On the bell housing question, a lot of the racers run the "built" C4 and put on a SFI 460 bell housing. Maybe that doesn't help in this discussion since it was not a stock offering, but if you look at these bell housing specs they don't state the bell housing requires the use a specific starter type (early or late). I don't know if this adds any useful information to the discussion.
So I think you have correctly explained it - the early and late model starters have different tooth counts and different centerlines. But they are interchangeable between early and late model engines.
#34
I think that we would have to see the engineering drawings for SFI bellhousings, but i bet a C6 aftermarket bell puts the starter closer to the crank than one for a manual like a TKO-600
***and shares a starter***
The throwout on PMGR starters differs between manual and auto.
I have had them side by side.
#35
Yes, it was stated/thought that that the manual and auto trans take a different starter, but NumberDummy says there is just one starter p/n for both.
When I went to RockAuto site to see for myself - there was not a distinction between the transmission type.
#36
Numberdummy states that a starter with an engineering date of *1981* is the same for both (and im not disputing that)
Starting in 1992.....
Ford's part number for automatic PMGR is F2TU-11000-BA (Lester 3226)
For a manual it is F2TU-11000-CA (Lester 3225)
Make what you want of that.
I know my 3225 doesn't hang up in the flywheel when I let off the key.
#37
None, because if they did, would know there's only one 460 starter for A/T & M/T
1983 was the first year that M/T (& 4WD) were available for 460's, all 1968/82 460's came with the C6.
btw AFAIK: Only Gary Lewis, ctubutis and myself have this parts catalog, but there are probably others (excepting these knowledgeable people) that have it.
Kyle Wood
22
09-06-2023 08:23 PM
JJJRoberts
16
02-14-2012 10:22 AM
JJJRoberts
02-11-2012 02:11 PM
