Looks great. Does it mount in the factory tow hook location? I'd assume the tow hooks get removed as they are virtually worthless with the bullbar in place???
Looks good. I would like to get one (or atleast get new brackets for the one that came off my 2016) but they interfere with the adaptive cruise control.
Yeah, won't work with adaptive cruise, but I don't have it. The tow hooks stay in place. It uses two of the OEM bolts and is a really easy install. N-Fab makes a light bar mount that works with the Cruise Control, but I had to send that bar back twice because their quality control sucked.
Looks nice. Like the lights in the grill too. Who makes them?
ZROADZ makes them. They were a little bit of a bitch to put in. If you do it, make sure you use a drill bit made for plastic. You have to drill 4 small holes in the backside of the grille.
Any chance you could take a couple of pictures showing the tow hooks and the accessibility of them -- are they still able to be used?
Thanks
Tow hooks become useless. They are directly behind the lower bar.
I don't plan on having to be pulled out, and if I have to pull someone out, I have a D ring that installs in my hitch receiver.
