Project Fitty8
Project Fitty8
hello, new(ish) member, finally just inherated my pop's old truck.
58 Styleside
Shortbed
223
3 on the tree
2wd
its been sitting in my grandma's warehouse since the early 90's
still in planning stages (and i gotta see if i can get it running)
Back before it got parked, it was having trouble with oil pressure. It would idle fine, but any throttle would drop oil pressure completey. He passed away in the early 90's so we dont know for sure what he had done to try to fix it, my gma says he changed the oil pump, but was never able to locate the correct bearings and the truck has been parked since
Solid Truck, i am excited
pictures coming in a few
58 Styleside
Shortbed
223
3 on the tree
2wd
So far the run down of what it needs to be road worthy so far.
New Brake Master Cylinder
New Clutch Master Cylinder
New Clutch Slave Cylinder
New Fuel Pump
Clean out Gas Tank (In progress)
New Flex fuel hose from tank to frame
new flex fuel hose from frame to fuel pump
new brakes
new tires/wheels
Leak from Rear Diff
Replace windshield (i have spare)
Possible others
Carb rebuild or new
Starter (maybe)
I havent even attempted to start the truck yet, still trying to get the fuel system restored and collect parts that i need, (wife wont let me spend money on it yet)
This truck is in great shape, just extremely dirty, so dirty that almost every think was ceased until i cleaned it up (choke, e brake, normal brakes, clutch, most of the pull *****)
I was going to attempt to start it after i get the 2 new flex fuel lines, fuel pump, and re install the cleaned out gas tank. and a battery. not sure if the carb is going to be worth a damn after almost 30 years of sitting. Once it finally starts then i can check the other issues, see what the deal with the loss of oil pressure is/was that my grandpa last worked on
heres a few more pics
seat and tank out
starting to clean the rusty gas tank
mechanical fuel pump to be replaced
had to pull the ignition switch to take to locksmith to get a key made. Just had one made for the door hoping they were the same key, but i was wrong
New Fuel Pump
new brakes
new tires/wheels
Leak from Rear Diff
Possible others
Carb rebuild or new
Starter (maybe)
seat and tank out
ID Tag
New Fuel Lines
Tank is back in after being cleaned out
new fuel pump
had the truck started and running. sounded like it had a misfire. checked a wire and it broke, so replaced wires, cap, rotor. Replacement rotor broke right when i tried to turn it over.
i figured i had probably check the plugs too...they seem to be in good shape...right?
flash makes it look better
Probably need new ignition coil as well as new plugs. then ill try to get it started again.
Also something strange happened... the clutch hydraulics were dry. i added fluid a few weeks ago just for whatever reason. the Slave didnt move at all. After i got it started a couple days ago, the clutch was back... Full Pressure and i didnt pump it up or anything. It just works now lol
That truck is incredibly good shape. I hope you keep it as original as possible since it is so "unmodified" now. Your truck do as you wish.
If the 93K miles is correct that 6 cylinder is likely in need of a rebuild, oil pressure is a good indicator of that (worn main and connecting rod bearings). I doubt the issue is the oil pump. The plugs also look like it was using a good bit of oil (another indication that it needs rebuilt). Rebuilding the engine is not a difficult job.
If you do plan to try to start it, you may want to put some (maybe 1/4 cup each) MMO or ATF down each cylinder and let it soak several days. That will free up any rings that have become stuck while sitting. Leaving it in the oil should help loosen the valves as well. After that check compression and it will further tell the story.
Good luck, hope this is helful.
the truck actually wants to start and run but I keep getting defective parts. So far new distributor rotor broke almost immediately then I put the old one back in with new cap just to try it out and the old one broke. Cheap distributor cap. Got a replacement one of a better brand and it fires up with starting fluid. Now I'm waiting to get a replacement fuel pump to replace the one I got 4 days ago... So if I can get it fuel I believe it will start and run. Just annoying having bad new parts
fall update
Made a lot of progress! just in life, not the truck....
I was playing around with the 223 for a bit, but with as many miles as it had before it was parked (with mechanical issues), i just didnt want to dump any money into something i was intending on replacing anyways.
Funds have been tight, but i should be picking up a Crown Vic IFS and i think that will be my starting point. I still need to find a new transmission to pair up with a 302 that i plan on building. I dont plan on doing THAT much to the truck, i just want it a little lower, better suspension, and some 'get up and go'. I may put some power steering and brakes in, but i want this thing to stay vintage-ish. I know some people here love unaltered trucks, but i am only doing what my dad was intended on doing to this truck. I love patina, just not this candy cane color scheme, its not for me.
Can someone enlighten me on what they earned the nickname "Fridge"?
