Massage Seat Won't Work
Anyone know why just my driver's side massage seat won't work? It started out intermittent but won't come on at all now. When I touch massage on the screen it just won't go there. When I hit the side button on the seat, it still doesn't come on. Everything else works on the seat. Passenger side works fine.
Mine starting having problems with the side button but would come on through settings. I reset my sync and haven't had a problem since (odd, I know).
If I remember correctly, hold power and skip forward buttons until it restarts. If that's not it, do a quick search here-there's a thread that describes the restart procedure.
It’s probably the a connector under the seat. Here is a link for a TSB on the massage seat for some info on the connector.
https://static.oemdtc.com/TSB/MC-10169898-0001.pdf
There’s a connector under the seat that can short out one of the pins causing the heated and cooled seats to stop working. Check all the connectors.
FordMarine431
2009 - 2014 F150
07-28-2017 09:46 PM
