Bed Leaning A-Starboard?
So since I've had my '71 F-100, the bed seems to lean to the right/passenger's side. I've been told it's likely the cab that's leaning left, that the cab mount bushings are likely collapsed, causing the cab to lean to the left/driver's side, but I have serious doubts about that. Looking at the truck, it looks as if the cab is level, but the bed seems tilty. I took a tape measure to the front fenders to measure the distance from the bottoms of the fenders to the ground when the truck was on pavement, but it seemed level. Anybody else had this happen with the bed?
on
I had a weak front passenger leaf spring that was really noticeable when, I had my c/o camper loaded on the back. Thiers many possibilities for the sagging to one side..
The cab front cushions, front cab mounts, rear cab cushions or rusted out rear cab cross member which most of the time can all be found up on closer inspection.
Orich
Orich
Orich
Orich
Mine does that also. But my bed floor is tweaked just a bit. I've figured someone in my truck's past loaded too much, too heavy, too fast on the right side of my bed. Mainly towards the back. The tweak in my floor shows the R/R corner of the bed was forced down farther than what the floor wants.
falcon50
07-21-2004 03:20 PM
StephenKnight
06-22-2003 11:28 AM
Jag Red 54
05-28-2003 09:48 AM
