To replace injectors or to not?
#31
Jim advised me against the single shots because of the tuning difficulties. I was told that that's why he offers the 80% split shots. He said he's been doing this for 12 years and most people have a very difficult time tuning single shot injectors and end up buying his 80% split shots instead. I explained to him I was going to use a very reputable tuner like dp tuner, power hungry, etc. His response to me was get ready to pull your chip out 5-7 times and ship it back to get re tuned. I was very surprised with his responses. I'm not knocking Jim but it's news to me about these issues with single shots. After talking with P.I.S. and Jody at dp tuner I'm told that tuning isn't an issue.
#32
I always thought no matter what upgrade you did you had to get your chip retuned. My mistake. Lack of knowledge. That's why I was asking questions like that while talking to Jody.
#33
You can put new tunes on a PHP chip with a laptop and the USB cable (which is included with the tuner). I don't know what this nonsense is about shipping your tuner back and forth. Do people still buy hardware that works this way? I bet they still own betamax VCRs too.
#34
#35
I know I will be getting new 160/80 single shot injectors because of their reputation for a great towing and everyday injector.
I already purchased the Hydra through GearHead, so I will have my tune emailed to me and load them myself.
Sit back, have a nice cool beverage of your choice and weigh your options. It is your money, time and truck.
#37
I think that I understand what Jim meant exactly based upon two things. One of them being the TS chip with the other being rather obvious.
If I were in Jim's shoes and understood the limitations that the OP built for himself, I would probably recommend the exact same thing.
Jim suggests who to tune the 80% splits....because they dang sure won't perform correctly on stock split tuning.
#39
I need the deep trans pan for the transmission temp sensor fitting. It's a derale stamped steel pan. They are cheap.
I'm sure dp tuning is a lot better than the TS chip I have. Must be way better than the edge cts I had on my excursion that fried my pcm, bcm, key sensor ring in steering column, and my ficm.
#40
Save your money on that derale pan.
Stewart
#41
DP tuning is the software provider for the hardware. The F5, F6, TS chip, Hydra, etc are all hardware items that the tuning is downloaded onto.
Stewart
#43
Originally Posted by andym
I don't know what angle Jim is shooting here but this is completely false.
My truck runs great with single shots and I only got one set of tunes from gearhead.
It does idle a little rougher though. It shakes the cab at red lights a little more than stock injectors but that's why split shots were developed (as I understand it) - to smooth out the idle.
I'd say Jim has been in it long enough to know of what he speaks. I'd take his word as the final say. Unless you can give me singles and have it idling baby-butt smooth as well running like a raped ape, no thanks. To each his own though.
#45
There's a reason the PHP Hydra keeps getting recommended.
