3.5 EcoBoost pretty much a direct bolt in to any 65-79 Truck - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Engine Swaps
Reload this Page >
  #31
Old 09-11-2018, 04:37 PM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
Backyard Project Manager
Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.
Originally Posted by Emontanez View Post
Would it be possible to get some of those pm details from you? Definitely interested in buying engine and tranny for ecoboost swap and wanted to learn a little more on the subject. Thanks
You do not have enough posts to allow a PM
  #32
Old 10-15-2018, 03:01 PM
eclectix
eclectix is offline
eclectix is starting off with a positive reputation.
nice thread! bookmarking
1968 f250 4x4 flatbed modified
1968 bronco wagon modified
1966 bronco roadster restoration project
2000 explorer stock RIP
  #33
Old 11-04-2018, 04:10 PM
Boss9F100's Avatar
Boss9F100
Yet another!
2.7 into a 10th Gen Truck!
Too easy! Direct bolt in using stock crossmember. Just move crossmember back a few inches into existing holes. About a 5 min job.
  #34
Old 11-06-2018, 09:32 AM
EllieMae94's Avatar
EllieMae94
EllieMae94 is offline
EllieMae94 is starting off with a positive reputation.
Wow, that's great! Do you have completed project pictures, or is it still a work in progress?
How difficult do you think it would be to put a 2.7 into a 9th Gen OBS truck that's 4x4?
  #35
Old 11-06-2018, 12:31 PM
Boss9F100's Avatar
Boss9F100
should not be an issue in any truck with 34 wide frame. Perfect fit in 1965-79 4x4 so cannot imagine any Ford truck it would be issue fitting it
I will find pics of a 2.7 in a 1966 4x4.
Have also done 2 3.5 eco in 1966 4x2s.
I like packaging a bit a bit better on 2015 & up ecos.
  #36
Old 11-06-2018, 12:37 PM
Boss9F100's Avatar
Boss9F100
  #37
Old 11-06-2018, 12:39 PM
Boss9F100's Avatar
Boss9F100
All wiring needed to make it run.
  #38
Old 11-06-2018, 02:57 PM
EllieMae94's Avatar
EllieMae94
This is intriguing. That 2.7 has more power, torque, and should get double the fuel mileage than my mildly built 351w. I'm surprised more people aren't doing this swap. Your picture above shows the steering column and climate control system. These are required to perform the swap? What about the instrument cluster. Can the 2.7 Ecoboost swap be done on these trucks without changing those things? I'm reading through your thread on garage journal now, impressive work!
  #39
Old 11-06-2018, 09:05 PM
Boss9F100's Avatar
Boss9F100
Eco1 had all electronics.
Eco2 is 180 deg off. Using just what is needed to properly work engine and transmission. Using stock steering column with stock dash but gauges have been upgraded to look stock but are actually aftermarket to work with canbus.
For a swap one can use the one plugin cluster from donor truck or there is plenty of aftermarket clusters avail.
Next up swap hoping to select electronics I want in build.
balingwire
2009 - 2014 F150
09-07-2017 01:05 PM
Kelleyt217
08-20-2017 09:11 PM
uppernorth
2015+ F150
03-13-2017 12:58 PM
IntrstlarOvrdrve
09-09-2016 05:36 PM
madscientist
2015+ F150
18
04-29-2016 12:33 PM
Quick Reply: 3.5 EcoBoost pretty much a direct bolt in to any 65-79 Truck
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
