Better/best turbo and pedestal orings?
on
Does any particular type or brand or color orings make a better seal and last longer in our turbos and pedestals?
Yellow?
Viton is supposed to be good, but it's the fuel in our system that went to ULSD and eats everything, not the oil, right?
So is there a PROVEN better product? I understand we have 'preferred vendors'
IE the fluoro...version of orings for the fuel bowls are better. I have those. What about the turbo and pedestal orings?
Thanks!
Yellow?
Thanks!
I'm all for learning all I can about O rings as I think that there is nothing too special about the ones in our trucks and that they are one of those things that we get raked over the coals on in pricing. Fortunately they're cheap even when marked up 500% but it still gets my goat. So...what is a 'flouro' O ring? How does it compare with a 'Viton' O ring? According to this site Viton is DuPont's brand name for their 'flouro' O rings. Is this wrong? Here is a little about it.
Viton O-rings - Fluorocarbon V75 FKM - The O-ring Store
And then here is springerpop's list of them and where they can be obtained for $.30/ea but have to be bought 25 at a time.
Powerstroke O-Ring Chart
I got them from my local seal distributor/manufacturer for $5.00 for the four of them.
on
Made me look it up...LOL.
Fluorosilicone. Read about it here: Ford 7.3 Diesel Fluorosilcone Drain Valve O-rings
Blue Fluorosilicone: The Blue Fluorosilicone elastomer is a Military Specification material that has a much wider temperature range than Viton (A) or Viton (B) and is widely used where fuel contains corrosive agents that are found in ULSD. Bio and veggie fuels. They will stay flexible in arctic conditions down to -70º F and can withstand temperatures in excess of 400 F.
From Parker Hannifin :
"In the automotive market, fluorosilicones are the seal material of choice for handling gasoline, E85, diesel fuel, biodiesel and ULSD at extremely low temperatures."
on
I didn't know if there was an oversized oring that is better, higher temp (viton, right?), or something else that would be more forgiving and longer lasting?
The sealing is done by the squashed oring, not the aluminum/steel mating surfaces, right?
Maybe a squared oring (gasket) would work better?
I am not an oring expert, but for a couple of dollars each, we should be getting some pretty stout seals
OK, Fluorosilicone sounds good, good to colder temps than Viton. The fuel bowl rebuild kit I got has a 'Viton' sticker on the bag. And with Viton being good to -20 it leaves me wondering about those days and areas where they get to -30 or even lower. Something like that brought the space shuttle Challenger down.
Yes, the O ring fills a void and gets squashed into it to seal it. The base of your pedestal contacts the top of the block on the bottom and the bottom of your turbo up top. I would expect that the void and O ring size are calibrated and a little too big or too small could be an issue. There are some square O rings, I believe that one or two on the injectors are square.
I use Viton when I can get it. I get my O-rings from Bob (dieselorings.com) and Clay (riffraffdiesel.com).
I used this kit for re-install: Turbo Re-Install Kit GTP38 for Ford 7.3L (99-03) - GZ-14-009
Two years later and no problems with it.
Thank goodness our oring's are not a Criticality 1 component like the ones on the Challenger SRB. They knew they should have waited until the afternoon, or until it warmed to 54 degrees. When the oring failed on launch the Challenger should have blown up right there on the pad, but aluminum oxides filled the void until shear winds tore it back open halfway into it's 73 second flight. The sky was so clear and blue that day half of Florida could watch the launch. The only positive thing that happened from NASA's and Morton Thiokol's greed was the SRB's after that were the safest thing on the shuttle.....very sad!
Hey Now.
Viton is floro is florosilocone.
Fluorocarbon is fishing line.
As for O-rings, its Silicon, Buna-N, Viton, EPDM, and Kalrez.
Their is also a Chemrez, but In think it's the same a Kalrez.
Epdm is also known a EPM.
So whats the best choice, Kalrez.
O-rings come is std sizes, once you. know the size, you can find your o-rings.
FYI expect to pay about 10x as much for Kalrez! So do you still need the best?
Then pony up boys!
Then pony up boys!
I would think in the turbo pedestal heat is the biggest issue, so which one stands up to the heat the best?
I did mine a year ago and used Viton from Bob. I replaced all the o-rings in the top end at the same time. It has been over a year now since I have seen a drop of oil or diesel under my truck, it's a great feeling!
Hey Now.
Then pony up boys!
Then pony up boys!
Here is a link to a vendor of a wide variety of O rings and descriptions of what they are good for.
AS568 Standard Size O-Rings
And here is springerpop's page on O ring sizes and places to buy them.
But I agree with you that, for the most part, O rings are O rings and if you know your size and have a local vendor you can get them for a fraction of the price of what 'Powerstroke' vendors sell them for.
GondolaRides
02-10-2013 10:47 PM
