The E-brake light stays on.
I was talking about the e-brake pedal switch, since in the original post they said, "My E-brake light stays on all of the time." You of all people should've realized that.
parking brake light stays on
My 2019 does it also. I put truck in park and put brake on and off a few times. Sometimes just pulling the handle a few times corrects it. I’m going to investigate further, lubricate cable, handle and pedal parts. I haven’t checked the fluid level, low brake fluid usually indicates brake wear. I only have 18K miles and that light would not go out from messing with the parking brake. It seems to happen intermittently on my truck.
E brake light stays on
This was an EZ fix for me. The switch worked fine. When I pressed it FULLY with my finger the light went off. The metal tab on the parking brake pedal assembly was not FULLY pressing on the switch. I bent the tab about 1/8” to make more contact with the switch and it solved the problem.
Volvo92906
09-24-2009 06:00 PM
