Nice!... This is what I am looking to do.
Looks like u have a 6.2L gas? I am being told and saw a few posts on web...stating 3.5" readylift SST with the 1" lift at rear WON'T work on the 6.2L trucks.. ready lift said it will fit... But might hit exhaust...and front drive shaft on heavy off road use.
Did you install it? Or a shop? Any issues? Did you add any caster bushings or anything? Thanks for ur help.
Yes It's a 2018 6.2L and I had it professionally installed. No issues what's so ever and no extra bushings, they just installed what came in the kit.
Stock 18" wheels with 35/12.5/18 BFG KO2s and the 2.5 Readylift Level. No rubbing whatsoever like has been stated and so far seems to ride even better than stock.
Looks great, I have 20's stock wheels, would I be able to use BFG KOs on mine??
My mind is blown that I haven’t posted in this thread since I’m pretty promiscuous with topics about bigger tires on these bad boys.
37x12.5” on stock wheels and springs; sway bar and radius arms to clear lock to lock:
