New to the forum 74 f100 2wd swb.
#76
Good evening all. Does anyone here have a suggestion on a chrome brake booster/mc combo? My proportioning valve is below the cab on drivers side. Although it was originally located on the steering gear box. inline tube sent me the lines that terminate under the cab at a prop valve there. I purchased a adjustable prop valve from speedway it is a cpp. I'm confident it will work fine, now I cannot find a booster/mc combo (chrome) I hope someone here can be of some help. Thank you for taking the time to read this.
#77
Here is a chrome 7" double diaphragm booster:
Universal 7" Dual Diaphragm Booster Chrome - Pirate Jack
And here is a matching 'corvette style' master cylinder:
MC1321ACHFT - GM Universal Aluminum Chrome Master Cylinder, - Pirate Jack
On the MC, make sure you get a disc/disc or disc/drum unit to match your setup.
#78
and my part # that was shipped matched the part # in there catalog for a 74 f100 2wd short bed. Well for some reason I received a brake line kit for a 73.
I don't believe I'm the only one that has received the wrong brake line kit.
This in turn is where all my confusion is coming in to play, I don't have enough knowledge of brake systems to know exactly what I can and cannot make work. I have emailed LMC with this issue and have yet to get any response. I'll keep yall posted as to what information I may get.
#79
#88
#89
