Wiper Washer heads and hose - Just a FYI
34,000 miles and mine on my 2015 and they started acting up. Thanks for the link. Mine is covered under warranty but I don't feel taking it in.
How long does it take to change?
Thanks for the Linky
Bruce
Bruce
They appear to be simply held into the hole in the hood with a plastic clip that is built-in. Digging out the broken piece in the tube might take some time but it shouldn't be too much longer than changing wiper blades. I'll let you know when they finally come in if someone doesn't beat me to it.
Bruce
Bruce
Thought I would post a few pictures and a comment or two.
This project takes about 10 minutes, including taking the pictures. Anyone can do this.
These are the parts that were sent from Amazon. All Ford parts:
First I worked on disconnection of the hose from the white clip on the old unit.
This clip exists on the new part, just pull this one out of the hood.
Push the clips together on the underside of each sprayer. My sprayers fell apart when I pushed on the clips.
This white piece (blue circle) just pulls out of the black plug (yellow circle). The part that you see in the yellow circle will get re-connected to the white clip on the new hose.
#29
I attempted to use my wiper washers this morning on the way to work. Nothing out of the driver side and only a dribble from the passenger side. My first thought was they ingested small particles and just needed a cleaning. Upon opening the hood the rubber hose routed to the drivers side nozzle was laying on top of the engine. Dang 37 months and only 38k miles and they are failing already!
Thanks to you fine folks posting in this thread I was ready and had replacement nozzles on the shelf.
#30
