Where do I find connector pins!?
I have a WPT-570 (Tin) 3U2Z-14S411-VLA connector and I'm looking for the female pins that go into the connector that can be crimped onto the wires. I've checked auto parts stores and dealerships and the only thing I can from them is the whole pigtail and I'm not spending $75 for a whole pig tail when only one wire was chewed on by a mouse. Any guidance on where I can get pins or better yet and assortment of pins would be greatly appreciated!!!
Sorry...I did not get notified of your reply.
What is you application and what circuit are you working with?
If you found the proper OEM connector (MOTORCRAFT), did you see the short PN on the bag? Usually you can buy these fairly cheap online and it saves you a ton of trouble as only a large shop would carry a terminal assortment (you know, NAPA might have such a selection).
-Wiring Pigtail Kits Identification Guide-
BTW- Weatherpack is a GM term...
1973FE
22
04-13-2019 11:56 PM
IsItFast?
11-24-2008 02:57 PM
Watcher
11-02-2004 09:01 AM
