1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Broken tab on electrical plug to COP 6.8L 2003...what to do???
Old 05-26-2017, 07:59 PM
SoCalAngler's Avatar
SoCalAngler
SoCalAngler is offline
So I started changing the plugs on my 2003 F-350 6.8L/4R100 this afternoon.
One of the tabs on the electrical plug that connects to the COP (on cyl #8) broke right off.
Dealer wants $68 for a new one!!!! Dealer states that the new plug has a 4" pigtail with butt connectors.
Since this is the first one that broke, and I'm only into the third plug, this can get expensive!!!
I've been VERY careful and not wiggling the connector....Pressing tab with finger or flat head screwdriver and pulling straight out.
1. What is done to fix this issue?
2. Do you replace with dealer part, cutting wire to loom and then using butt connector as dealer parts counter suggested?
3. Aftermarket part?
Bummed that this had stopped my work on plugs that I was hoping to finish tomorrow AM
Thanks!
Old 05-26-2017, 08:18 PM
SnowPlowDriver's Avatar
SnowPlowDriver
SnowPlowDriver is offline
There are sets of 8 on ebay for less than $25.Looks like a common problem.
Old 05-26-2017, 11:32 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Rock Auto has them starting at $7.75.
Any big name auto parts store should carry Dorman brand. Part # is Dorman 645570. If they don't have it in stock most stores can get it overnight or hotshot it from another store. This is a very common part, used on Fords for a couple of decades, any parts store should stock it in at least one of various brands. While you are shopping, you might want to check the availability of the injector connector for the same reason.
Hint: the clip just holds the connector onto the coil. A broken clip will not keep the coil from firing. It will usually stay on there well enough to get you to the parts store as long as the road isn't too bumpy. Some people have been known to rig up a nylon zippy tie to hold the connector onto the coil until next payday.
Old 05-27-2017, 04:59 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
Below is the source of dealer parts-
-Motorcraft® Wiring Connector Catalog-
Use the MOTORCRAFT PN (short number) to search online (e-Bay - Online Discount FORD Dealers) for better pricing.
Old 05-27-2017, 08:28 AM
SoCalAngler
KULTULZ.....that is a great pdf! All of us should have this!
Thanks
Wonder if the Ford plus are any better than...... the ones from eBay, Dorman, or other Chinese made ones?
Old 05-27-2017, 09:52 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Zip ties.
Been there, done that. They're still working after several years.
Old 05-27-2017, 08:42 PM
SoCalAngler
picked one up at NAPA for $20.
Think I'll purchase a few from eBay to have on hand. They're 8 for like $15
Old 05-28-2017, 03:07 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
I am a purist and when repairing a car want no song-and-dance and/or comebacks. I use only OEM parts unless a vendor part is known superior or doing HI-PO work.
I am the wrong guy to answer that question...
polar888
2004 - 2008 F150
11-11-2016 07:44 PM
VannerDude
02-11-2015 06:39 AM
mkoempel
11-06-2011 06:56 PM
ktm450exc
Modular V8 (4.6L, 5.4L)
03-15-2011 10:04 PM
Mr Stacy A
1997-2006 Expedition & Navigator
09-05-2009 07:26 PM
Quick Reply: Broken tab on electrical plug to COP 6.8L 2003...what to do???
