99 SD 4r100 to NV4500 swap
Hi all, need help with wiring problem after putting a Cummins, and a nv4500 5spd. in a 99 f350 that had a 7.3 auto. Everything is in runs, and drives, but now the wipers, and power windows won't work. I'm sure some one else has done this swap, but can't find anything about the auto trans wiring. Thanks
You can rip the entire auto trans harness out and it won't effect the wipers or windows.
My 04 has 2 hot leads coming off the batteries that power the fuse box, pull the fuses and check both sides of the fuse plug to see if one side is hot with the key on.
I think you may have left a wire unhooked.
I'm guessing the engine and trans came together making it the cheapest and easiest way to do the conversion.
Several have done that swap, I'm just not a fan of a nv4500.
1320stang
1997 - 2003 F150
12-31-2015 07:34 PM
64rarebird
02-22-2014 02:44 PM
ReBilld
16
06-29-2013 11:54 PM
dougbrown
1999 to 2016 Super Duty
11-19-2009 12:33 AM
