Mid-engine, Twin Turbo, '51 F1 Build Thread, pic heavy
Back-story:
My Grandpa left me his one owner 1951 F1. It was the truck he got around in for his logging and excavating company. It's mostly beyond repair since tree fell on it. I'm just going to hold onto it until I get better at body work and have the patience to make it original. I also have a spare 52 F1 that was an old "police truck" that I will use to restore my Grandpas truck. (with the spot light)
But until then...I'm working on a ******* of a project that most will either love or hate. I want a custom hot-rod. (I’m just not ready to call it a rat rod yet)
Slight change of plan from my introduction thread. I picked up a ‘51 F1 project for $2,300 down in Portland, OR. It came with a title from 1963 that was signed in 1986. The gal was really confused when I walked into the license office to transfer it into my name. Her boss told her to make a copy and let me keep the old title because it would add value to the truck.
According to the owner: “it had been sold several times as a project, each owner did something to it, some of it good.”
I really didn’t want to have to show the State Patrol what I am creating. I’m very happy to start out with a title.
It will look like a stock/ front slightly dropped F1 truck with a hood in the bed. It will be powered by a 6G72 3.0L Twin Turbo 3000GT engine. I can upgrade to a 3.5L later. I'm going to replace the rear axle of the truck with the front clip of the car. It will fit inside of the bed and look stock from the outside and the hood of the car will open out of the bed. The Volare bolt pattern conveniently matches the bolt pattern of the 3000GT.
As far as I can tell/research no one else has done this in a truck. Maybe there's a reason for that I will find out the hard way...
It came with a Volare front suspension, ford 9” rear diff, and 2” chopped off the cab-which still needs some work. Someone put a 48-50 bed on it, the metal bed liner is kind of cool, too bad it has to go to make it mid-engine, I’ll save it to sell or for my Grandpa’s truck.
Engine:
Powered by a Twin Turbo 6G72 V6 320 HP@ 9 Psi, I’ll copy the mods in my other car and start with 400hp @14 Psi with just basic performance mods, maxing out the stock fuel system: 360cc injectors and stock computer so no tuning is needed.
Transmission:
Getrag 5 speed AWD tranny converted to “FWD”
Paint/body:
I’m going to make the frame and cab very nice, seal the parts I’m keeping with epoxy, primer what will get replaced later, and paint it without much body work to the fenders and damaged pieces. I really just want to get everything working and driving by next summer. Or at least the engine running.
Challenges:
Finishing the chop top will be tough, it’s very thin in one place. I will have to have custom glass made, not sure how the side windows will work out.
Fitting wide enough tires to get traction, I can’t go in any further because I’m up against the strut tower. I will either have to jack up the rear end a bit or cut out the fenders a bit.
Reversing the shifter cable/ shifter to accommodate the engine being in the rear.
I’ll have to make a bar to replace the steering rack. Maybe a piece of all-thread with ends to make it able to be aligned still.
Stay tuned, so far I’ve remembered to take pictures.
I have the bed mostly unbolted and should be test fitting the front end of the 3000GT to the this weekend!
This is my Grandpas Truck
Fit up from another F1 frame I have and a spare stripped front clip from a 3000GT.
Engine:
Transmission:
Paint/body:
Challenges:
Welcome to FTE. Your project sounds . . . Different.
I have driven a Dodge Stealth R/T with that engine and while it made the 4WD/AWS Stealth move right along I'm not sure how it will do in a truck that doesn't have a sports car suspension and body. I would suggest that you do lots of drawings and sketches in order to keep your project on track with your vision. Things have a tendency to get out of hand sometimes and people get discouraged as you can tell by the "project truck" that you bought.
JDM Spec Engines - Mitsubishi 6G72 Engine
... I'm not sure how it will do in a truck that doesn't have a sports car suspension and body...
I'm ready for a challenge, I've built a few race cars over the years. But, I'm also open to aborting and throwing a big block in since it has the firewall and rear diff for it. Everything I'm doing is reversable and I'm using parts I already have. I'm definitely going to have it fitted up and drive it before thinking about that, however.
I'll think about the hood trim, I might go single spear.
Very cool idea, and ambitious. It will definitely solve the weight distribution problem. My truck was so light in the rear end I had to go with a limited slip rear end or risk getting t boned. With open rear end on a wet road (lots of those in Oregon) it just spun one tire.
A few years ago at work they had a 1960 Econoline van that they decided to get rid of. I was very tempted to buy it and put a FWD drivetrain in tit. Read "wheelie" mobile.
Some people add weight in the bed over the rear wheels.
Very cool idea, and ambitious. It will definitely solve the weight distribution problem. My truck was so light in the rear end I had to go with a limited slip rear end or risk getting t boned. With open rear end on a wet road (lots of those in Oregon) it just spun one tire..
Thanks das, I really think it will change the way it handles a lot. I hope the FWD suspension holds up, I need to brace it so it can't turn or flex.
I got way farther than I thought I would today. I would have gotta a nice test fit if the rear diff hadn't gotten in the way. It seem like I need to move that table...
I'm lucky I had some dollies to move this.
What a waste, I think i already has limited slip.
Lift off!
Bound up on the dang table, my car port is too small for this maneuver.
Lift off!
