2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
EZ Drain Valve. Time to drain.
Old 05-24-2017, 05:15 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
How long to drain the oil with an EZ Drain/Fumoto? This long:
Old 05-24-2017, 05:21 PM
System's Avatar
System
System is online now
Prolocutor
Received 1,188 Likes on 572 Posts
Well, not every drop...
Old 05-24-2017, 05:22 PM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
But you left about 2 oz in the oil Pan! That cant be good for the engine!
Old 05-24-2017, 05:23 PM
PwerStroke99
By the way, was the engine warm or cold?
Old 05-24-2017, 05:46 PM
EpicCowlick
Engine was warm but not hot. I waited about a half hour after driving to drain. Next time I want to drain with the oil HOT as that will move faster and drag whatever it can out with it.
Old 05-24-2017, 06:09 PM
PwerStroke99
Yea, id be curious to see the time difference
Old 05-24-2017, 06:54 PM
DL222's Avatar
DL222
DL222 is offline
EZ Drain Valve I got a magnet on the oil pan. Well if EpicCowlick is doing it me too.
Please don't jump off a bridge.
Old 05-24-2017, 07:18 PM
EpicCowlick
LOL. I promise. I usually just cause people to involuntarily spend their upgrade budgets. You know, when one jumps, everyone follows...
Old 05-24-2017, 08:35 PM
das_16's Avatar
das_16
das_16 is offline
best mod to not make a mess when changing oil lol
Old 05-24-2017, 10:19 PM
AMXDREAMER's Avatar
AMXDREAMER
AMXDREAMER is offline
Was the filter on or off the engine during the draining?
Old 05-24-2017, 10:38 PM
EpicCowlick
The filter was still on when the oil was drained. The oil cap was off and the dip stick was partly pulled out though.
Old 05-24-2017, 11:22 PM
Habemus Quattro's Avatar
Habemus Quattro
Habemus Quattro is offline
Now if only Ford would ditch the silly spin on oil filter and use a top-side cartridge. Nobody would spill a drop of oil ever again.
Old 05-25-2017, 05:06 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
I use the ez drain on my 2013. I usually attach a hose to it so I can move the drain pan under the oil filter and do that at the same time.
I use a 1 gallon milk container that I cut the top off and left the handle intact. As you loosen the filter and it starts to drain into the pan I will put that container under it and spin it off.
Then to kill time I drain the fuel/water separator and do all my underside inspections.
Old 05-25-2017, 07:06 AM
gwcon's Avatar
gwcon
gwcon is offline
I miss the topside cartridge as well.
Old 05-25-2017, 07:49 AM
bushpilot's Avatar
bushpilot
bushpilot is offline
if you think you're getting a complete/bone dry drain (via removal of the conventional drain plug) you're fooling yourself. The 6.0L had .9 quarts that remained in a reservoir for the HPOP and that remaining quart never had any impact on the engine or wear.
you'll always have oil left in a motor after any change.
I can tell you thru YEARS of sampling - if any oil is left in the system after an oil change its does little to impact the engine and wear.
Quick Reply: EZ Drain Valve. Time to drain.
