Thought I had a 2 inch leveling kit?
I recently bought a 2010 F150 4x4 with a 5.4. I'm new to this body style and have been doing as much research as I can and one of them is trying to find out how much lift I have.
I had another F150 owner ask me yesterday what lift I had and I said I had no idea that i thought it was a 2 inch leveling lift. he said not that he had it on his truck and my truck was clearly sitting taller than his.
I can not tell if I have the spacers in the front or not and or if the front coil over shocks are stock or not. I did replace the rear rough country shocks with Bilstein 5100. When i try to measure out the fronts it seems like they may be on the extreme extended side of things. But that's another topic.
My question is, can you have a spacer and a 2 inch coil over shock with the stock suspension? The tires 325/60/18. It does appear that the upper control arm may rub the coil spring when the suspension is fully extended.
